100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous?
Old Jan 7, 2003 | 07:36 PM
totaled's Avatar
Default 100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous?
Is a 100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous? Will it greatly reduce the motor life? (66k miles right now)
Old Jan 7, 2003 | 07:44 PM
freakin_eLRoD's Avatar
Default Re: 100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous? (totaled)
Don't do it.....
Old Jan 7, 2003 | 07:56 PM
EVIL Hx Coupe's Avatar
Default Re: 100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous? (96jdmcoupe)
Dont even try it. Motor go Boom!!!
Old Jan 7, 2003 | 07:59 PM
delslo's Avatar
Default Re: 100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous? (Boost Pressure)
how bout a 1oo shot single fogger on a d16y8 fully built block <no head work>with STR blok gard? gonna go boom
Old Jan 7, 2003 | 08:00 PM
IWearMyKswiss's Avatar
New User
are you freaking serious??? if so then i hope you have another motor waiting to swap in,..my boy put a 100 shot on his ZC motor (after countless times of begging him not to because i knew he would blow his shiet) ,...one pass down the track is all he got to run,..needless to say im not one to say i told you so but damn i think i mentioned it to him about 40 something times after that,...he kept on saying well your running a 75 shot,..yea well ive also upgraded my fuel system and did the main things i had to do to run a 75 shot,...plus my LS motor is a 98,..his was alot older
Old Jan 7, 2003 | 08:18 PM
General Kills's Avatar
Default Re: 100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous? (WiDeBoDyEK)
Would a 50 shot with stock internals be alright for a d16y8?
Old Jan 7, 2003 | 08:42 PM
Default Re: 100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous? (Tunerdude)
50 shot should be fine....just don't run crazy advanced timing and if you can, retard ignition timing a bit and run colder plugs to be on the safe side....
Old Jan 8, 2003 | 02:15 PM
totaled's Avatar
Where in San Diego do you live? im looking for a good shop to get some **** at and some work like a b18c5 swap if i get into UCSD^^
Old Jan 8, 2003 | 02:45 PM
JpiZz0's Avatar
THATS REALLY BAD!!! do 100 on a wet shot a little bit safer but no guarantees try a smaller shot
Solo2Vtec's Avatar
**** mine blew with only 75 shot. I got one whole bottle but as soon as I refilled it the motor thru rods out the front and back of the block hehehe
[Modified by Solo2Vtec, 8:32 AM 1/9/2003]
Old Jan 8, 2003 | 02:48 PM
JpiZz0's Avatar
Default Re: 100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous? (Solo2Vtec)
that sux bro were using a stock bottom end?
Old Jan 8, 2003 | 02:50 PM
midorigreen.'s Avatar
Default Re: 100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous? (jPs vTec)
my brother ran a 70 shot on his stock ls motor then swapped in a b20 and the first day he forgot to put in the pill so he was shooting about give or take 100-125 and it was running fine...even beat a s2k
Old Jan 8, 2003 | 03:46 PM
Mugen_Power's Avatar
Default Re: 100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous? (ekekekekek)
blowing up your motor isnt a good idea...woud dohc be better?
btw can i kno which motor is better
DOHC F20c (s2k engine)
DOHC d16y8
DOHC d16y7
and SOHC of those motors
which one is the best?
Old Jan 8, 2003 | 07:14 PM
New User
Default Re: 100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous? (Mugen_Power)
DOHC d16y8
DOHC d16y7
to my knowledge the "DOHC D16y8" and DOHC D16y7" that you are asking about do not exist,..these are only SOHC motors
Old Jan 8, 2003 | 07:27 PM
serious?????
but d16y engines are derived from the original s2k engine isnt it? i thought all s2k engines had DOHC
Old Jan 8, 2003 | 07:34 PM
hawk's Avatar
if you do it and blow up your motor, good things may come from it swap perhaps??
Old Jan 8, 2003 | 07:39 PM
email me if you have any questions, always glad to help.
Old Jan 8, 2003 | 07:53 PM
totaled's Avatar
Where in San Diego do u live?
Old Jan 8, 2003 | 09:20 PM
chad's Avatar
Moderator
i put about 30 bottle through a 1991 dx engine....with a 75 shot of NAWWWWSSSSZZZZ and it was a dry shot...
Old Jan 8, 2003 | 09:35 PM
I'm in and out of Chula Vista and Paradise Hills
Old Jan 8, 2003 | 09:47 PM
BackSideSA's Avatar
are ya'll idiots...
my d series motor is the shizit y0!!!
Old Jan 8, 2003 | 10:28 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: 100 Shot Dry Nos Setup from FX on a SOHC d16y8 dangerous? (HybridHackBatch)
with proper tuning, you can safely run up to 1/2 of your wheel horsepower, unless fully built. That's why you'll see the 5.0's running 100 shots fine, but CX blowing to bits
fdjizm
Feb 14, 2007 07:18 AM
JDM STYLE
13
Jun 5, 2005 08:19 PM
CRXstress
11
Jun 1, 2005 08:20 AM
MonsterVtec
Aug 17, 2003 12:14 AM
