What is this bolt hole for?
Old Jan 7, 2003 | 06:16 PM
crxgurlllll's Avatar
Default What is this bolt hole for?
Please forgive me if this is a dumb question....
i was looking around checking my engine mount bolts and everything making sure they were tight.....i noticed there isnt a bolt in that hole...i see its threaded on the side i took the pic from, but i try to stick a small screwdriver thru and it hits something almost immediately.... im guessing its to seperate the tranny and engine.....or maybe something else went there? any help appreciated
(btw this is a b16 in a crx and the pic shows the bolt right below the hole is the top rear bracket bolt and the cable pictured is for the speedo)
Old Jan 7, 2003 | 06:55 PM
Lamchop0000's Avatar
Default Re: What is this bolt hole for? (crxgurlllll)
this is a sir swap correct? maybe that other hole was for the sir rear engine bracket, and if you used a integra piece maybe it doenst bolt up to those?
[Modified by lamchop0000, 7:55 PM 1/7/2003]
Old Jan 7, 2003 | 06:56 PM
S13 slide's Avatar
i just checked mines and theres nothing there too... so i dont think its something to worry about.
[Modified by S13 slide, 4:03 AM 1/8/2003]
Old Jan 7, 2003 | 08:12 PM
USDM 4G VTEC's Avatar
that seems to be in the engine block...
well lets see if someone else comes foward without it.. then i tmight be ok
wevtech
Feb 8, 2011 07:05 PM
theidealone
Nov 27, 2010 07:45 PM
91EF919
Mar 21, 2009 05:13 PM
civickiller
Aug 16, 2005 09:15 AM
216.226.142.95:27016
Jul 3, 2003 10:20 PM
