I just broke this! Help me out pls!!!
Old Jan 7, 2003 | 03:01 PM
FUP23's Avatar
New User
Default I just broke this! Help me out pls!!!
I just snapped the top off and its just fucked ...Question is can i run it straight from the intake manafold to the black box it goes to ?? Thanks alot devin
Old Jan 7, 2003 | 04:20 PM
deftones0817's Avatar
Default Re: I just broke this! Help me out pls!!! (Devin17)
is that a vaccum hose? If so buy a new one I can't see what he is talking about but its from the fuel rail to the engine????
DEF
Old Jan 7, 2003 | 04:24 PM
turbod16y7vtec's Avatar
Default Re: I just broke this! Help me out pls!!! (deftones0817)
can you take a better pic? i can't really tell what it is.. thanks
Old Jan 7, 2003 | 04:25 PM
Phaze2 Mike's Avatar
is that a PCV valve, if so, its a joke to fix, your local parts place will have it for like $5-$10.
Old Jan 7, 2003 | 04:30 PM
tominos's Avatar
Default Re: I just broke this! Help me out pls!!! (Nextekhatch)
can't see what u broke. looks like a vacuum hose you circled.
Old Jan 7, 2003 | 04:37 PM
FUP23's Avatar
New User
YEAH its goes to that valve and then goes to the black box under the intake manafold. ...can i just run a straight through line and bypas the pvc valve
Old Jan 7, 2003 | 05:24 PM
FUP23's Avatar
New User
ttt please help
Old Jan 7, 2003 | 05:59 PM
FUP23's Avatar
New User
In that pic its not broken!!! Its broke now sorry had to clear things up
Old Jan 7, 2003 | 06:55 PM
sloppy_seconds's Avatar
Banned
if it's a "plug" that goes from a black vacuum hose to a black box, then YES it's your PCV valve. probably $4 at a parts store.
Old Jan 7, 2003 | 07:27 PM
eg6ajk's Avatar
you can block it so that there is no vacum leak on the intake side, then drive to pep boys (insert your favourite store here) an pick up one up for less then $5 and replace it.
86 FI PCV are all pretty much the same and interchangable (usually marked PM6)
Old Jan 8, 2003 | 06:48 AM
FUP23's Avatar
New User
Default Re: I just broke this! Help me out pls!!! (eg6ajk)
thanks alot guys!
lotofIntegraty
Apr 11, 2010 06:58 AM
bdjimz
Dec 25, 2008 08:31 AM
drew_kousk
Jul 26, 2008 09:21 AM
yostuhfoo
May 16, 2007 09:43 AM
pg_thao
May 21, 2002 03:52 PM
