Side mirror difference between 92-95 hatch - 96 and up civic and Integras.
Old Jan 7, 2003 | 01:47 PM
IdotheSHOCKER's Avatar
Default Side mirror difference between 92-95 hatch - 96 and up civic and Integras.
How is fitment if say you were able to find side mirrors for your 92-95 hatch for a cheaper price but they were for the DC2s or 96 and up civics?? Will it work?
Old Jan 7, 2003 | 11:55 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: Side mirror difference between 92-95 hatch - 96 and up civic and Integras. (EGB18hatch)
At one time wanted to find this information out, a bump for a possible answer. I personally doubt the ones listed will fit without trimming the exterior casing. I would be more tempted to try installing crx or 90-93 model teg mirrors.
Old Jan 8, 2003 | 12:13 AM
BenB's Avatar
Here is some 96-00 Civic mirrors on a 92 CX. My friend said it was a pain in the *** to get them to fit - so to answer your question, it can be done.
[Modified by BenB, 9:14 AM 1/8/2003]
Old Jan 8, 2003 | 12:19 AM
chad's Avatar
Moderator
Default Re: Side mirror difference between 92-95 hatch - 96 and up civic and Integras. (BenB)
like you said PITA.....why when it is soo much trouble!
Old Jan 8, 2003 | 02:00 AM
Soulless's Avatar
Default Re: Side mirror difference between 92-95 hatch - 96 and up civic and Integras. (chad)
ill be doin this to mine soon, all you have to do is use a dremel and open up the stock hole a bit for what you need for the 96-00 mirrors to fit. Ive talked to 2 people that have dont it and they both said its rather easy, but you need a ddremel and take your time, you dont want to mess up.
Im doing it to get rid ofthe M3 mirrors i bought a while back.
Old Jan 8, 2003 | 03:10 AM
Default Re: Side mirror difference between 92-95 hatch - 96 and up civic and Integras. (Soulless)
I was thinking the same thing... the cheapest mirrors I found were like M3 mirrors lol or spoon copies. But I found a pair of 99 stock civic mirrors for a way cheaper price.
Old Jan 8, 2003 | 04:01 AM
rolow's Avatar
That is pretty much it.
I used 96 electric because they where free and my drivers side mirror was broken then I bought the car.
I think the electric mirrors where easyer to put in because I did not have to cut a hole for the joy stick on the manuals. I just tucked the electric plug inside the mirror.
I just opened up the 3 stock holes to mount the mirror
here is a bad pic.
New pics coming
[Modified by rolow, 4:18 PM 1/8/2003]
Old Jan 8, 2003 | 07:00 AM
SloCivicHMM's Avatar
Default Re: Side mirror difference between 92-95 hatch - 96 and up civic and Integras. (rolow)
so they are a direct bolt on after openning the holes?? or do I need to cut the outside plastic???
I'd like to do this to my 92 vx???
Old Jan 8, 2003 | 07:03 AM
Zer0DazE's Avatar
Default Re: Side mirror difference between 92-95 hatch - 96 and up civic and Integras. (SlowCivicHmm)
i would like to see a close up like that last pic, but of the outside.
Old Jan 8, 2003 | 07:08 AM
rolow's Avatar
Default Re: Side mirror difference between 92-95 hatch - 96 and up civic and Integras. (Zer0DazE)
Of my pic?
Old Jan 8, 2003 | 07:17 AM
Zer0DazE's Avatar
yep
i wanna see how well it lines up
thanks
[Modified by Zer0DazE, 11:18 AM 1/8/2003]
Old Jan 8, 2003 | 07:35 AM
rolow's Avatar
Here is the mounted mirror
Here is a pic of the 2 holes I had to open up these holes are for the cover plate clips
Here is the back of the modified mirror note this is a electric mirror and the plug is tucked inside and wraped in duck tape
The finished look
here are fitment pics
[Modified by rolow, 4:38 PM 1/8/2003]
Old Jan 8, 2003 | 08:01 AM
Zer0DazE's Avatar
thanks
that looks good, i assume you need to use 2 door/3 door mirrors.
Old Jan 8, 2003 | 08:08 AM
rolow's Avatar
thanks
I used 2 door on HB
Old Jan 8, 2003 | 08:13 AM
what do you mean modified mirrors??? what did you do to them....I'm under the asumption that all that has to be modd'd is the door???
Old Jan 8, 2003 | 08:25 AM
rolow's Avatar
I used electric mirrors that have a plug on them for the electrical harness you have to tuck the plug inside the mirror or cut another hole in the door to make it fit I modified the mirror insted of cutting a hole in the door
Old Jan 8, 2003 | 09:32 AM
sweet...I'm going to look for some and throw them on....thanks bro....I'l post pics later...hahah
Old Jan 8, 2003 | 04:27 PM
Thanks for the illustrations man, appreciate it. Good Tech stuff.
Old Jan 8, 2003 | 04:48 PM
eg6ajk's Avatar
rolow:
how is the view out of these? just as good as stock?
Old Jan 9, 2003 | 07:01 AM
Default Re: Side mirror difference between 92-95 hatch - 96 and up civic and Integras. (eg6ajk)
stock vs stock...enough said bro!!
Old Jan 9, 2003 | 07:24 AM
rolow's Avatar
rolow:
I don't think there was any differance.
Old Jan 9, 2003 | 09:40 AM
kefka's Avatar
nice pics, not that i would ever want to do that, but i always wondered how to do it. nice job.
Old Jan 10, 2003 | 06:13 AM
Found me a set of 97 hatch mirrors.....would these work??? any ideas.....well I got them for free...so I'll see.......
Sidenote....these are the manual mirror with the interior ****....I'm hoping the **** lines up too that would complete the look...
Old Jan 10, 2003 | 09:15 AM
rolow's Avatar
I am all most 100% positive that the **** wont line up.
but I hope it does good luck
Old Jan 10, 2003 | 09:20 AM
rolow's Avatar
I hope I got the right pic
In this pic you can see where the **** is supposed to go thru the door and is now used as a mounting point for the mirror itself.
Also to the bottom left of the same washer you can see the hole where the electric plug is suposed to be
I would think that the **** would use the same hole
[Modified by rolow, 6:21 PM 1/10/2003]
