headlight power loss
Old Jan 7, 2003 | 01:41 PM
DJ KrunchyKracker's Avatar
Default headlight power loss
my friend has a 91 prelude 4ws. the motor was a 2.1 then he and his brother did a b20 motor swap before i ever met them so i dont know that everything was hooked up right but it all looks good under the hood. now the question is that all of the lights on the car ie, dash clock headlights, dim when he hits the gas but only when the car is in gear. we have already replaced the alternator thinking that might be the problem but it didnt solve it. we are kinda lost. if anybody has any thoughts please give some input.
[Modified by DJ KrunchyKracker, 5:27 PM 1/7/2003]
Old Jan 7, 2003 | 02:31 PM
Default Re: headlight power loss (DJ KrunchyKracker)
please someone help me. i cant see
Old Jan 7, 2003 | 02:37 PM
prelude1897's Avatar
Possibly the battery itself may need to be changed. Are the belts on tight enough?
Old Jan 7, 2003 | 02:43 PM
Default Re: headlight power loss (prelude1897)
battery is pretty new too i think. they never have a problem with it dying on them. and the batt is never dead when they try to start. i will check the belts here in like 5 minutes
Old Jan 7, 2003 | 04:54 PM
sslude's Avatar
pulley kit? i know that the pulley kits are known to dim lights when idle though.
Old Jan 8, 2003 | 08:13 AM
Sephro's Avatar
Are you sure that the alternator is the correct one for that engine? My thought is that the alt is not powerful enough so when you hit the gas power is being taken away from the accessories therefore making the lights dim. Also you may want to check your ground. Where the battery grounds to the frame take it off clean it up sand it down so that you have a good ground.
Old Jan 8, 2003 | 01:40 PM
Sticky Tires's Avatar
* B A N N E D *
Default Re: headlight power loss (Sephro)
try checkin the ground wires.
realred96
Classic Hondas
May 11, 2011 03:45 PM
d16lxciv
Mar 3, 2006 11:30 AM
stareatsun
Mar 9, 2005 10:26 AM
CHONCH
12
Sep 9, 2004 10:46 PM
Calavera
Aug 1, 2003 05:30 AM
