91 Std Hatch sway bar install??
Hopefully someone can help out with this. I did a search, but came up with nothing really to answer my question. Anyways, I have a 1991 civic hatch std. I bought the Suspension Tech. front and rear sway bar kit. I managed to get the rear bar on ok, but when it came to the front it appears I never had a stock bar up front. The holes in the control arm (I believe that's the piece) are there for the end links, but there are no mounting brackets to secure the bar to the frame or body. I may be completely stupid and missed the fact that there is something there to mount it up, but I'm just not seeing it. Maybe I could get some brackets from a Si or something? I'd really apreciate the help on this one. Thanks guys.
Didn't the front st bar come with "D" brackets??
If not you can get them from a si or buy them from honda but I would think the st kit should come with new hardware.
You will see where the brackets go on the bottom of the subframe the will be a slot then a hole for I believe a 12mm bolt. One end of the D bracket goes into the slot then the other end is bolted down.
No, the kit didn't come with the brackets. There was no way to specifically order for a std on the nopi.com website. Anyways, I'll check it out. Thanks for the help.
Alright, nevermind. There website isn't up yet, supposedly coming soon. There is a number there. When I looked back at Nopionline.com, I found I had ordered the kit for a car with a front sway bar. Do you think Suspension Techniques will be able to supply with the parts? Anyways, thanks for the help all.
JDM_dreamer
Jan 8, 2007 08:17 PM
katb16vo
22
Mar 25, 2004 03:29 PM
moridin2004
Jan 10, 2003 01:44 PM
