Blown Fuse
i've looked everywhere. where does the wire COME from? cause then i could towards that direction. most of the wires for the stereo come from the passenger side, like behind the glove compartment. is that were the (+) 12 volt ignition wire comes from too? there should be 2 ignition wires, and i have neither.
They go towards driver side. They actually go down, then under the carpet, i think, then along the tube frame up under the driver side dash. Kind of a pain cause there isn't much room. It's easier if you have the stereo out.
it's probably a wire right behind the deck that gets pinched when you put it back in. All you need is a little nick in the insulation and that could touch ground to blow a fuse. There is a lot of sharp metal that makes a good ground back there.
i seriously spent all day looking for my 2 (+)12 volt ignition wires. can't find then anywhere. i need some help. i don't really have the money to pay someone to do it. any help is really appricaiated.
Just run new ones to your ignition harness. Just be sure to fuse them. Can't remember colors, possibly white/yellow for 12 V constant, and Yellow for switched? Just use a meter.
About the meter. You should get a Digital Multi Meter at Radio Shack for a cheap one. You really don't need one though as a test light will suffice for most. Just don't poke anything with yellow or orange loom around it.
This will save you a lot of trouble down the road. Only 15 bucks.
http://www.radioshack.com/product.as...%5Fid=22%2D810
thanks. yeah i do need a helms. im gonna pick one up this weekend. i'm gonna go try using those pages as guides now, hope it works. i'll keep you posted.
