help with headlight rewiring on jdm front end.........
Old Jan 7, 2003 | 08:37 AM
XEF-9X's Avatar
Default help with headlight rewiring on jdm front end.........
what all is involved could someone give me a step by step if possible...... and also im guessing im gonna need to buy some.. where can i get the jdm h4 bulbs for a decent price online??
Old Jan 7, 2003 | 09:03 AM
EF_LSVtec's Avatar
Default Re: help with headlight rewiring on jdm front end......... (XEF-8X)
Its easy...I'd run a search because this topic has been discussed over and over....
Old Jan 7, 2003 | 09:15 AM
XEF-9X's Avatar
Default Re: help with headlight rewiring on jdm front end......... (EF_LSVtec)
ya i know i looked but i couldnt really find anything specific. if anyone can find something more specific let me know. thanx!
Old Jan 7, 2003 | 11:13 AM
bryant's Avatar
cut your wires and hack up the H4H harness. connect things together. (test lights are your friend)
Old Jan 7, 2003 | 11:20 AM
keithv's Avatar
Default Re: help with headlight rewiring on jdm front end......... (CR-X)
this won't help you out specifically, but whenever i have to swap wires and the connectors use the same metal ends, i just re-pin the connector you need to use. this way you are not cutting wires then soldering. and if you make a mistake its easier to fix.
just my $0.02.
Old Jan 8, 2003 | 06:37 AM
EF_LSVtec's Avatar
Default Re: help with headlight rewiring on jdm front end......... (breaka_1_9)
I agree with Breaka_1_9 ...But to answer your question about rewiring (I guess you didnt find a thread)...You need 3 wires to make the jdm H4 work...Get the lead wire on each of your high and low beam lights and 1 of the ground wires (makes 3) connect and tape...
Old Jan 8, 2003 | 06:41 AM
XEF-9X's Avatar
ya i figured it was that easy but i thought id just make sure. thanx
Old Jan 8, 2003 | 07:48 AM
EF_LSVtec's Avatar
deanh8
Jul 22, 2006 11:07 AM
gtowni3
Sep 11, 2005 10:51 AM
Beezle
Aug 24, 2005 10:49 PM
Mr.Fairlady
May 6, 2004 03:25 AM
FusionITR
Jan 26, 2002 11:18 AM
