Just ordered ITR rear sway bar... cant wait!
I ordered everything for under $90 from acuraautomotiveparts.com.. anybody ordered from here, and how long should i expect it to take? Are the itr sway bar parts still in huge demand and backorder everywhere? Now all I need is a BSQ mounting kit.. I hope this mod will be worth the money
for the money, i haven't made a better upgrade to my car. i love the itr rear sway, it's a difference of day and night in handling. enjoy, but def get the reinforcement kit.
Scary
Scary
Nope, they are pretty quick about getting it out. They are based in GA so mostly it dpnds on how far you are for UPS to reach you. If the part is back ordered they will contact you and let you know. From what I hear this really helps tighten up the car's handling. Probably the next mod I am going to do.
I recieved my ITR bar and accessories last night. My BSQ kit also came a week earlier.
For those to have it installed, what do you normally do with the ABS mounting brackets? Do they fit under the BSQ kit or are they discarded and tied down with wireties?
These are going into the car this weekend and I want to see if i can do my homework prior. Searching gives ample information but not exactly what im looking for.
Cheers,
Al
Cheers,
Al
Yeah, i just ordered mine the other day and along with the BSQ kit.
can't wait to feel the difference. The guy that i talked to when ordering said it will be alot stiffer and make the ride alot harsher. i've actually never heard that from anyone, but i don't care. twisties here i come
whats the difference from the BSQ kit, and beaks? i know the cost is differnt, and obviously how they look, but anything else? the BSQ kit looks just like the stuff that came with my suspension tech. 19mm bar..
Got my rear sway bar and BSQ kit sitting in my room as I type this. Gonna wait til winter is over ( I Live in Canada) because I have stock 14's w/winter tires
on it right now and we have recieved about 3-4 feet
of snow over the last week. If I put it on now I don't think I would be able to drive my car like I would want to, to feel improvements it will make. I can not wait til spring!!!!!
My car was lowered as well when I put the ITR rear sway on, and it made a huge difference. You will notice it just in daily driving. The car basically has zero roll in turns. Huge difference.
[Modified by BSQ, 4:46 PM 1/7/2003]
I just installed my JDM rear sway bar this past Saturday. For the time being I have left the ABS sensor wires dangling. I plan to do something with them once I install the Neuspeed lower tie bar. Here's a pic:
Install was a breeze. Only took me about hour, including putting the rear up on jack stands and removing the wheels. This is with the BSQ kit btw.
[Modified by Chris L, 8:22 PM 1/7/2003]
[Modified by Chris L, 7:58 AM 1/8/2003]
That guy doesn't know what he is talking about. The only thing the car does it reduces car roll in turning. You can take corners a lot faster. It basically reduces understeer. Doesn't make the ride harsher at all.
The important thing though is how much this affects the ride, and to me it's not very much. Maybe if you're used to riding in a limo or something you'll notice. This is the reason I always use the web interface when ordering stuff like this whenever possible; I hate talking to those morons who try to talk you out of everything ("what do you need one of those for?").
90 shipped for everything??? and did you order online? cuz i went there and nothing came up when i looked for the swaybar.
1.) Go to http://www.acuraautomotiveparts.net/...searchpart.jsp and enter the following part numbers to order:
52300-ST7-Z01 rear swaybar
52315-ST7-Z01 swaybar bushing (2 needed)
52308-SS0-000 bushing bracket (2 needed)
52316-ST7-Z00 endlink bushing (2 needed)
52312-ST7-Z00 endlink bushing collar (4 needed) – this part can be reused from the stock swaybar
90175-ST7-Z00 bolt (8x35) (2 needed)
94050-08080 flange nut (8mm) (2 needed)
Here's how:
Here's how:
ill be ordering your mounting kit shortly.
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
I still need an ITR rear sway. This is my next mod.
