how to remove rear seats to get to fuel pump?
i looked around the other day and i tried lifting them but it felt like i was gonna break something up, ive had my new pump sitting in my living room for awhile now and i wanna get the thing in
u should fold down the seat and take those carpet behind the seat. its only a plastic so they are pretty easy to snap. then get a size 10mm socket and take thos bolts behind the seat. then lift the seat, the seat is pretty hard since its ur first time but just lift them up and it will snap...and theres it is...u can take the fuel pump now...hope this helps...if theres more ques just pm me
ahh i dont remimber the exact order .. but its very easy the (2) backs of the seat come off Seperately ... and the bottom seat is one long bench that has a L shapped hook in a slot ... take the backs off first .. then the bottom bench ... there is a bolt holding the bench you got to break loose before they come out ... youll see the fuel tank lid under the seat
[Modified by zilverz, 4:57 PM 1/7/2003]
Doh, I have a DC2. I would imagine the seat bolts are located somewhere along the perimeter of the seat cushion.
Be careful not to pull with force in the front as the front hooks can get bent and you'll have a wobbly seat once you reinstall it. Mind did that until i adjusted the metal hooks.
GooD Luck
GooD Luck
mrbojangles2013
Feb 16, 2013 06:00 PM
sageuvagony
Dec 25, 2008 12:54 PM
