Hondata Stage 3B
Old Jan 7, 2003 | 01:53 AM
Unlimited's Avatar
New User
Default Hondata Stage 3B
anyone using this on their itr with todab cams?
what ecu are you using p28 or p72?
i've been recommended S100 / S200 and now 3B
did you get the INAKE MANIFOLD GASKET? Yes? No?
who did your tuning and how much was it?
what kind of harness do you have and how much was it?
did they tune by your rpms / air fuel / wide band o2?
[Modified by Unlimited, 3:10 AM 1/7/2003]
Old Jan 7, 2003 | 05:52 AM
vtec.dc2's Avatar
Default Re: Hondata Stage 3B (Unlimited)
all of the options you listed will work with your setup, i'd recommend their latest s100/s200, s100 is cheaper but you can not upgrade and not datalogging, s200 is much better than 3b, cause you could just start with s200 and add whatever needed. and yes, tuning is best with wideband O2. Both p28 and p72 will work, p72 has factory knock sensor support, that will work at partial throttle.
Old Jan 7, 2003 | 08:39 AM
Austin's Avatar
I'm currently running a P28 based stage 2, the stage 3 includes the full throttle shifting, and the launch limiter, the "B" at the end denotes that it's for boost, so you do not need that.
Hondata has now come out with their S100, and S200 series, S100 is all inside the ecu, S200 is still an outboard box, however it's easier to upgrade to the datalogging, and adding the full throttle shifting and launch limiter.
My opinion is to purchase the base S200 system from an authorized Hondata dealer in your area and have them tune it for you.
Austin
Old Jan 7, 2003 | 10:31 AM
sgT's Avatar
sgT
Default Re: Hondata Stage 3B (Austin)
FYI, 3b is for FI applications. it can be used for NA, but you are spending extra money for nothing
Old Jan 7, 2003 | 01:24 PM
azn98R's Avatar
P28 with Hondata Stage 3
GUILOTINE
Dec 8, 2005 10:47 PM
Liquidgsr
Mar 8, 2005 02:57 PM
D3LSLO
Aug 6, 2004 01:18 PM
hYpE-R-29
Apr 6, 2003 11:33 PM
