Question with T1R B-pipe~~~~~~~~~
Old Jan 6, 2003 | 08:39 PM
itr1244's Avatar
Default Question with T1R B-pipe~~~~~~~~~
I just installed T1R B-pipe and T1R test pipe.
It rattles at low rpm.. sounds like it's hitting metal.. but not sure if it does.
sounds comes from the "middle" of the pipe. where the resonator(spelling) is...
is it normal or mine is installed wrong?
Old Jan 6, 2003 | 08:45 PM
disordeR's Avatar
Default Re: Question with T1R B-pipe~~~~~~~~~ (itr1244)
it's hitting against heat shields. take your plyers and bend the heat shields just BEFORE and around the S-pipe. i believe it rattles at the flanges of the S-pipe and the mid section of the b-pipe.
had the same problem, bent em, problem solved.
Old Jan 6, 2003 | 08:46 PM
itr1244's Avatar
Default Re: Question with T1R B-pipe~~~~~~~~~ (disordeR)
beautiful
Old Jan 6, 2003 | 09:34 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
could also be the hangar.
Mine rattles like pennies in a jar when I hit the gas., and at idle. Gets annoying when you're having that in-car pillow talk with your lady right before you drive her home.
Edit - my bad, I thought you were talking about your Spoon N1 again for some reason. scratch the hangar comment
[Modified by Ross, 1:35 AM 1/7/2003]
Old Jan 6, 2003 | 09:35 PM
skafia's Avatar
25 Year Member
I took some sheet metal shears and cut about 4-5 inches off of the rear shield at the bend. Doesn't rattle at all now.
Old Jan 6, 2003 | 11:17 PM
itr1244's Avatar
Default Re: Question with T1R B-pipe~~~~~~~~~ (s k a f i a)
so is it better to just take out the heatshield??
Old Jan 6, 2003 | 11:20 PM
B2FiNiTY's Avatar
Just bend it with your hands. Takes 1 minute and stilll functional.
Old Jan 6, 2003 | 11:21 PM
mantic6t9's Avatar
Default Re: Question with T1R B-pipe~~~~~~~~~ (B2FiNiTY)
Yep had to do this with my old apex n1.
Old Jan 6, 2003 | 11:23 PM
itr1244's Avatar
True
Old Jan 6, 2003 | 11:33 PM
itr1244's Avatar
Default Re: Question with T1R B-pipe~~~~~~~~~ (mantic6t9)
sorry it's stupid to ask ... which way should i bend it? like upward? or what?
little more detail plz?
Old Jan 6, 2003 | 11:37 PM
B2FiNiTY's Avatar
Easy: use your imagination.
Bend AWAY from the b-pipe so it does not hit the b-pipe.
Old Jan 6, 2003 | 11:40 PM
itr1244's Avatar
haha i was thinking bendaway. = upward.. and wtf? there must be no rooms to be bent. so i was like umm which way? lolz
well.. that's stupid Q..
thx anyways
Old Jan 6, 2003 | 11:44 PM
mantic6t9's Avatar
You can also grab it with a pair of pliers and kinda roll/bend it up.
Old Jan 7, 2003 | 06:10 AM
skafia's Avatar
25 Year Member
Tried that, still rattled like a bitch.
Old Jan 7, 2003 | 07:55 AM
Type-R Yo!'s Avatar
New User
I took out all the heatshield on my car when I install the Toda header, T1 B-pipe and Spoon N1.
[Modified by Type-R Yo!, 11:56 AM 1/7/2003]
Old Jan 7, 2003 | 12:43 PM
itr1244's Avatar
Default Re: Question with T1R B-pipe~~~~~~~~~ (Type-R Yo!)
how hot does your car get in summer??
i wanna take it out but i have no AC in summer.. that scares me
and where i live now is fugging hot as hell
Old Jan 7, 2003 | 02:18 PM
Type-R Yo!'s Avatar
New User
I live in Greenville , SC and the temperature here in the summer gets to maybe 100 at the most. In the car maybe 100-115. The center console (carpet and shifter) gets warm and that is it. AC what is that will I use it sometime but 50% of the time I just roll the window down.
Where do you live and how hot does it get in the summer?
Old Jan 7, 2003 | 02:20 PM
B2FiNiTY's Avatar
It doesn't really get that hot if you remove the heatshields.
Old Jan 8, 2003 | 01:43 AM
itr1244's Avatar
people with T1R B-pipe or any other kind of cat back with Test-pipe that is resonator on it. how loud does your R sounds?
Right now it's really loud.. I think it's almost not streetable at all.
at rpm 3-4 that's the loudest.. damn it. too loud.
is it the test pipe or the b-pipe that is making my R that loud?
when i down shift and rev-matching it almost sounds like open header.
is it normal to be that loud or is there something wrong with my setup?
thx
[Modified by itr1244, 10:44 AM 1/8/2003]
Old Jan 8, 2003 | 01:45 AM
B2FiNiTY's Avatar
It's the straight pipe. No doubt about it. Sounds like a race car huh
Old Jan 8, 2003 | 02:01 AM
itr1244's Avatar
yeah it sounds pretty crazy..
i dont know if i can keep driving around like this loud DAILY
damn. i think i will have to get silenser.
Old Jan 8, 2003 | 04:12 PM
mantic6t9's Avatar
I just installed my t1r b-pipe and have the same problem. It was too dark to do anything about it. I think i'm going to have to cut some of the heat shield off, i won't know untill i get under it tomorrow and can see what going on.
White cracker yeehaa
Jan 15, 2006 03:08 PM
sp0017
Oct 9, 2003 06:14 PM
ScalawagD
Jul 12, 2002 06:58 PM
Cyberorth
Apr 15, 2002 09:52 PM
VTECAcuraGSR
Feb 18, 2002 09:29 PM
