Neuspeed lower tie bar + ITR sway bar compatibility
Old Jan 6, 2003 | 03:12 PM
Racer X's Avatar
Default Neuspeed lower tie bar + ITR sway bar compatibility
I already did a search but I only found one other post about this and the person got no reply. Is there any special mods besides the BSQ kit for the ITR sway bar? I want to add a Neuspeed lower tie bar and I didn't know if this would be compatible. Thanks in advance!
Old Jan 6, 2003 | 09:58 PM
Flamenco-T's Avatar
Default Re: Neuspeed lower tie bar + ITR sway bar compatibility (Racer X)
you need to get a longer bolts, at least an inch longer...
I am talking about the bolts that came with the neuspeed tie bar...
Old Jan 7, 2003 | 08:06 AM
zilverz's Avatar
Default Re: Neuspeed lower tie bar + ITR sway bar compatibility (Flamenco-T)
yup
Old Jan 16, 2003 | 10:37 PM
Kelvin96GSR's Avatar
25 Year Member
Default Re: Neuspeed lower tie bar + ITR sway bar compatibility (zilverz)
anyone know exactly what size to get?
Part # would even be better
Old Jan 16, 2003 | 10:48 PM
IN VTEC's Avatar
Default Re: Neuspeed lower tie bar + ITR sway bar compatibility (Kelvin96GSR)
10x1.25
I'd probably guess around 100mm (4").
You also need a .5" spacer...or use a crap load of M10 washers.
Old Jan 16, 2003 | 10:49 PM
Flamenco-T's Avatar
Default Re: Neuspeed lower tie bar + ITR sway bar compatibility (IN VTEC)
10x1.25
remember this ben ?
Old Jan 16, 2003 | 10:56 PM
IN VTEC's Avatar
Oh...Do I ever.
It was .
At least the bar makes a nice towel hanger if you can't use it.
Kyles ej1
Suspension & Brakes
Mar 27, 2005 12:17 PM
salvatore
Jun 26, 2004 09:17 AM
JFG Kevin
Mar 23, 2004 04:33 AM
Teknic73
Aug 27, 2003 08:16 AM
IntEGNYC
Jan 10, 2003 10:38 AM
