Lights
Old Jan 6, 2003 | 12:48 PM
UseR's Avatar
Default Lights
My previous owner of the car got into a crash but now the seat belt light is always on. Is there a way to repair this?
Old Jan 6, 2003 | 02:55 PM
Starrman85's Avatar
Default Re: Lights (UseR)
remove the bulb? =\
Old Jan 6, 2003 | 06:17 PM
iam7head's Avatar
Default Re: Lights (STARRMAN85)
"remove the bulb? =\"
that's deep..real deep.
what about start looking at the bolts tighting down the seat beats thing?
look for loose connector or so.
what is the light called again?
go see your manual for further instruction.
Old Jan 6, 2003 | 10:33 PM
Starrman85's Avatar
Default Re: Lights (iam7head)
yea, sorry for that post...anywayz, it might be a sensor in the buckle part, where the seat belt locks in. i kno if i do i just right, i can put the latch in, and push it a certain way to make the light go off, even tho the seat belt is not in. it might be stuck, and will not turn off? just a suggestion.
BTW, i do wear my seat belt, it was jus something i noticed one day when i didn't buckle all the way in, but the light didn't come on.
Old Jan 6, 2003 | 10:54 PM
ratherbewalking's Avatar
i unpluged the small harness under the seat of my 5th gen. that worked for me!
Old Jan 6, 2003 | 11:09 PM
iam7head's Avatar
Default Re: Lights (ratherbewalking)
I disconnected mine and set off the srs light.
btw it's on my 6th gen
[Modified by iam7head, 8:20 AM 1/7/2003]
Old Jan 7, 2003 | 08:57 AM
UseR's Avatar
HAHAA... well I meant repair, not end it for good! I want it to work like how its supposed to, thanks.
Old Jan 7, 2003 | 12:21 PM
Meisoslow's Avatar
Check the harness that you just unplugged from under your seat. Sometimes those things are faulty
Old Jan 7, 2003 | 12:26 PM
cyrixvsp2's Avatar
Default Re: Lights (Meisoslow)
check the wiring where the seatbelt plug is. That could be disconnected. If it's connected check for current. might be something wrong in the latch that's not connecting the circuit making the light go off. If that's the case honda is suppose to replace the latch for free. seat belt is warrenteed for life.
deving916
68
Mar 28, 2012 04:23 PM
ELSpool
Sep 9, 2005 07:31 AM
oldB18EF
10
Sep 20, 2004 05:20 PM
