Volk TE-37 w/ Falken Azenis--Rubbing??
Old Jan 6, 2003 | 10:08 AM
ITR#00-1077's Avatar
Default Volk TE-37 w/ Falken Azenis--Rubbing??
Picked up a set of 16x7 +42 Offset TE-37s yesterday... I have the R lowered with Spoon Springs... Tires on the wheels are Falken Azenis--205/50 R16.... Don't know if I did my search correctly..didn't find the right answers, but I was wondering if these wheels will rub under certain circumstances (major bumps or what not)... I have them installed on the R and how the Spoon Springs sit--the rear tends to be lower than the front... In the rear, there is no room for even a finger.. the front is ok....
I took the car out for a quick spin yesterday on the freeway and it seems fine, but I've read on a post before that the Azenis are a bit wider... now would a different brand of tire sit better on car?? Really don't want rubbing to occur...
Old Jan 6, 2003 | 10:10 AM
nfn15037's Avatar
Default Re: Volk TE-37 w/ Falken Azenis--Rubbing?? (ITR#00-1077)
My only worry with Azenis is the rear suspension. Sometimes the inside of the tire will rub, but all ya need is a lil spacer and yur good to go.
Old Jan 6, 2003 | 10:12 AM
Default Re: Volk TE-37 w/ Falken Azenis--Rubbing?? (nfn15037)
Not to sound slow, but what will the spacer do??... from the looks of things.. the wheel seems to almost sit under the fender a tad bit... it seems to be only 1cm away from rubbing the plastic lining on the fender....
Old Jan 6, 2003 | 10:16 AM
pleiades nutz's Avatar
I have the exact same setup as you and it WILL rub. Nothing too drastic, but mine rub in hard turns only. Other than that they are ok...so far, I have yet to track or Autox with them on. Hope I helped.
Old Jan 6, 2003 | 10:23 AM
Default Re: Volk TE-37 w/ Falken Azenis--Rubbing?? (oRgy)
Yeah, thanks... but I think autocrossing with them would cause real bad rubbing then... the Azenis just seem real wide... I saw a post once with a picture of the Azenis compared to another set of tires with the same specs and they seem way wider....
Old Jan 6, 2003 | 10:29 AM
After about two weeks with them on I pulled the wheels to check exactly where they were rubbing and it only seems to be about a 1 1/2 inch long area on the rubber liner thingy. I'm thinking of taking a rubber mallet to her....anyone wanna give out some tips in doing this?
ohhhhh wait, I just saw you have 205/50's...is that right? Mine are 215/45 16 so I am running wider than you. Mine are so minimal that with a 205 I dont think you would rub at all.
[Modified by oRgy, 1:33 PM 1/6/2003]
Old Jan 6, 2003 | 10:34 AM
Yeah, that's the difference alright.. I think if they were to be 45series tires... I would be OK, but 50.. that's a bit too tall...
98R-1144's Avatar
dont know if they will help..but i'm running 205/50/15 azenis on 15x7 +43 volks. i am still, however, on stock suspension. but I think if i did lower it, it would look like it would rub (especially in the rear), as the tires seem to sit "outside" the fender just a tad
Old Jan 6, 2003 | 10:37 AM
Default Re: Volk TE-37 w/ Falken Azenis--Rubbing?? (98R-1144)
I dunno if this helps, but here's a pic just to show how close it is....
Old Jan 6, 2003 | 10:42 AM
On your setup, you still have a gap... I don't.. the only way to feel the gap is to slide my finger between the gap.. and it's slim.... one more question on your setup.... is it ok to use the stock lugnuts with them?? or is it better to use the Volk nuts.... I was going to pick a set up as well....
Old Jan 6, 2003 | 10:51 AM
I wouldn't use stocks but the ones that come with the wheels(if you got them new)....if you want you can have mine that came with the wheels, I bought a set of the lightweight bling bling rays lugs.
Old Jan 6, 2003 | 01:11 PM
B2FiNiTY's Avatar
Get some tuner style ones. Stock will not seat correctly.
Old Jan 6, 2003 | 01:31 PM
nfn15037's Avatar
I didnt realize your car was so low, i was talking about spacing the wheel out so it doesnt rub on the rear suspension, but your car is damn low. Maybe roll the fender out slightly, or raise it up, its not good(handling wise) to have it so low.
Old Jan 6, 2003 | 01:44 PM
6ghatch's Avatar
Do they make 205-50-16? I thought the only 16" size was 215-45-16.
Old Jan 6, 2003 | 01:50 PM
DC2#428's Avatar
Default Re: Volk TE-37 w/ Falken Azenis--Rubbing?? (6ghatch)
well i had 205/55R16 tyres at one stage and they only rubbed upon full lock....45 series is best.
Old Jan 6, 2003 | 03:00 PM
Well, the Azenis on the wheels are 205/50R16... they were mounted on the wheels in Japan... I'll show some pictures tomorrow...
Old Jan 6, 2003 | 03:28 PM
frogsr's Avatar
i don't see why 205's would rub on your car... if they do, i would probably chance to guess that you're car is lowered too low. i have the same rims and am running the 215/45-16 azenis without any rubbing issues for daily driving. track/autox is a different story, since i have yet to run this particular setup on these rims/tires yet.
Old Jan 6, 2003 | 03:36 PM
TypeR 01 886's Avatar
Default Re: Volk TE-37 w/ Falken Azenis--Rubbing?? (frogsr)
Do you have a system in your car? I am not sure about the springs you have... but I have H&R sport springs on my car and it sits perfect. The back is barely higher than the front. I did have a problem when I had a system where the back did rub on the stock wheels with Falken Ziex tires.
Old Jan 6, 2003 | 08:51 PM
azn98R's Avatar
Have you thought about Bridgestone SO-3's in 205/50/16.... Lil wider than normal 205, but not as wide as Azenis.
Old Jan 7, 2003 | 05:06 AM
Default Re: Volk TE-37 w/ Falken Azenis--Rubbing?? (azn98R)
Any 215/45 tire should fit...its just that the Azenis run a little wide so there is some rubbing. If you are running a suspension setup then a 50 series tire in 16" is the wrong way to go. I have run 215/40 17" Yokahama's and had no problems at all.
Old Jan 7, 2003 | 08:08 AM
In Reply to:
frogsr--My car is lowered with Spoon Progressive Springs and the ride height and drop is good... I was just wondering if they would ever rub.. it hasn't yet.. I've taken it on the freeway at 65-70mph and at the end of the drive always check for rubbing, but none yet so I'm a little assured now that it won't.
TypeR 01 886--No system in my car.. not a big fan of them...IMO, it's just too much unnecessary weight...
azn98R--I've thought about the S0-3s... I'm trying to get a set for my stock set of rims (GM) and another set of Azenis for other set of stock rims (CW)... I was only wondering about the TE-37s because that's how they came when I got them..
Old Jan 7, 2003 | 08:55 AM
Here are a couple of pictures of the TE37s and them on the car:
This is a shot of the 96 ITR @ passwordJDM when I went down to LA to pick up the wheels...thanks to Steven @ passwordJDM
Sorry for the nasty night pictures... I tried to lighten them up as much as possible.. Will take more during the day....
Old Jan 7, 2003 | 09:09 AM
Man those look sweet
edit: Now all you need is some of my ghetto flat center caps
[Modified by oRgy, 12:10 PM 1/7/2003]
Old Jan 7, 2003 | 09:35 AM
ej1civic's Avatar
Default Re: Volk TE-37 w/ Falken Azenis--Rubbing?? (B2FiNiTY)
Stock lugs work fine with Volk TE37.
Old Jan 7, 2003 | 10:05 AM
Default Re: Volk TE-37 w/ Falken Azenis--Rubbing?? (ej1civic)
yeah, the stock nuts seem fine so far...
headtrner
Suspension & Brakes
52
May 22, 2013 07:28 PM
Brandeezy1
Jun 20, 2012 04:04 PM
riceburnah
Honda S2000
20
Nov 13, 2005 02:27 PM
ShoPlayHatch
23
Nov 12, 2004 07:07 AM
AamirCWITR
Aug 6, 2004 10:14 AM
