swapping ground effects on 1st gen....
is it possible to take the ground effects and rear and front bumpers off a 86 si (crx) and put them on a dx? is it easy...or a pan in the ***?
thanks
thanks
oh also, what about the center console out of an si into a dx? does it work, or will i have to take out my stereo face and all that to put into it?
center console will work, Ground effects im not too sure of. You will have to get the lower door skins if at all possible. You may even need the doors as well. The best way is to go to a junkyard that has both a DX and Si, take them both apart and test fit them. I'm 80% positive that it will work, what you will need is a different story. Id try it, but I dont have access to a DX Crx at the present time.
Only a Civic, and the doors are different.
HTH
~C~
HTH
~C~
yea the junkyard i go to has only 1 si and about ten dx or hfs....so yea i could probably do that. the si door skin panels are almost perfect, hardly any dings...atleast nothing that cant be fixed. i hope its not jacked by this weekend...
MLogan
22
Sep 7, 2003 08:47 PM
civicmark
Jul 13, 2003 08:45 PM
MilanoRex
18
Mar 8, 2002 09:17 AM
