rod bearing question
Old Jan 6, 2003 | 08:08 AM
JeremyL's Avatar
Default rod bearing question
when i build up my new block for my turbo project and i replace the rod bearings should i use gsr bearing, type r, civic si? do they all use the same size rod bearing? would there be any benefit from ls rod bearing to si, gsr, type r?
Old Jan 6, 2003 | 08:57 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: rod bearing question (JeremyL)
Honda has different sized bearings. So you have to check which ones you'll need.
Just as an FYI, Honda doesn't make any oversized bearings, so if you're cutting the crank, you can't use Honda ones. I used Clevite in my case.
Old Jan 6, 2003 | 10:39 AM
threatcon13's Avatar
New User
gsr rod bearings are color coded. there are different ones on different motors..not just a one size fits all deal.
Old Jan 6, 2003 | 01:59 PM
JeremyL's Avatar
Default Re: rod bearing question (ALLMOTORDC2)
goodgrief why would you cut the crank? wouldnt thaqt weaken it? just get a lighter forged crank
so i have to get the rod bearing specifically for a B18A1 block, i would think all B series cranks would have the same "size" rod bearings
Charlie Moua
Jan 16, 2012 07:01 PM
omglook89
Jul 14, 2011 08:49 PM
D.Dappa
Jul 16, 2007 01:57 PM
acrocat
Jun 15, 2007 06:34 AM
db2integra
Sep 20, 2004 08:25 PM
