tranny drift pin
Old Jan 5, 2003 | 07:04 PM
SIRX's Avatar
Default tranny drift pin
Well I went to knock that sucker out and I couldn't find the #@! #@!$ punch I have just for doing this. But I found out if you use a 5" 3/8 bolt and take it to the bench grinder you can make a great punch. The bolt was threaded about an inch, Use the grinder to just grind off the threads. This will be the perfect size to use. It took a test swing then 2 good hits and that sucker poped right out. I thought I would share.
Old Jan 5, 2003 | 07:26 PM
89civicdx's Avatar
Default Re: tranny drift pin (SIRX)
thanks for the info ,I hate that pin...just thought I would share.
Old Jan 5, 2003 | 07:46 PM
shortyz's Avatar
Default Re: tranny drift pin (89civicdx)
u know what i did. i took my air hammer bit (the round tapered one) and ground it down so it was long and thing to fit in there. that pin doesnt **** with me anymore.
putting it in i find is even more of a bitch!
Old Jan 5, 2003 | 07:58 PM
SIRX's Avatar
Default Re: tranny drift pin (shortyz)
naw I just put the pin in the freezer the night before (girlfriend hates that) I find that it shrinks enough to pound it in after you heat the other part with a touch. CARE SHOULD BE TAKEN HERE be very careful to not burn up that seal in there.
Old Jan 6, 2003 | 06:06 AM
SiR Kid's Avatar
New User
Default Re: tranny drift pin (efzero.com)
I use a 3/32 or 5/32 <can't rememeber> deep well, 1/4" socket. Works like a champ.
Old Jan 6, 2003 | 11:19 PM
MikeySpec's Avatar
Default Re: tranny drift pin (SiR Kid)
For those who do swaps often.Snap-on does make a punch for that.I think its like a 5/16th with a 3/8th nipple or vice versa.Guaranteed to work everytime..only runs about 20 bucks.Well worth it.
Mikey
tommybonnet2008
Dec 16, 2009 04:38 PM
thundernutz
Sep 27, 2009 04:22 AM
airwalk07143
Apr 11, 2006 09:28 PM
black_bb1
Dec 5, 2003 07:50 PM
gocivicgo
13
Jun 26, 2003 05:36 AM
