Need Z C Head
Old Jan 5, 2003 | 05:56 PM
KickinSi's Avatar
Default Need Z C Head
91 Hb with Z C block. Need DOHC head to finish swap. If anyone knows where i could get one or know of someone selling one please contact me. Would appreciate all the help I can get. Want to strike my ride asap.
Old Jan 5, 2003 | 06:14 PM
slow ride 74's Avatar
Default Re: Need Z C Head (KickinSi)
hey i have a head out of a 89 teg i think they are the same head ill sell it to you for $200.00 its portd and polished . i had it in my 84 civic turbo i threw a rod the head is good
Old Jan 5, 2003 | 07:28 PM
89civicdx's Avatar
Default Re: Need Z C Head (slow ride 74)
I have some zc cams with stock stock gears looking for $30(just incase you need some).
Old Jan 5, 2003 | 09:13 PM
Hondasaurs's Avatar
89 Integra head is no the same as the ZC. This pic shows an 89 Integra engine: Notice where the bolts are for the valve cover and where the Honda Symbol is on the valve cover. <P>
This is a ZC engine..... Notice the differences?
Old Jan 5, 2003 | 09:22 PM
AbaZ's Avatar
True the a1 head is not the "EXACT" same as the ZC. but it will bolt on and function.
Be aware that the reason the ZC has more HP than the A1 is the difference in the head. Whether its port design, cam size, intake manifold runner's, valve size. etc etc.
Jeff
Old Jan 5, 2003 | 11:08 PM
AbaZ's Avatar
Default Re: Need Z C Head (efzero.com)
They use the same pistons,
I have sets of a1 and ZC pistons in storage.. Both have same markings,
ZC has 9.5c/r
A1 has 9.5 c/r
Jeff
Old Jan 5, 2003 | 11:52 PM
*Boostwerks*'s Avatar
Default Re: Need Z C Head (AbaZ)
I beleive its the Cam's profile and the intake manifold design that makes the hp difference.
Both heads have the same valve sizes.
Old Jan 6, 2003 | 08:36 AM
DLB1994's Avatar
Default Re: Need Z C Head (Bryson)
i have a ZC head
Old Jan 6, 2003 | 10:16 PM
KickinSi's Avatar
Default Re: Need Z C Head (DLB1994)
Hey thanks for responding so fast. are you interested in selling the head. pls. let me know how much and also how to contact you asap. the sooner the better so i can start rollin my Si properly.
Old Jan 6, 2003 | 10:39 PM
xjoe's Avatar
i have zc head for sale, it's complete with everything from headgasket on up, including tb, intake man, dist, cams, rocker arms, valvetrain, fuel rail and injectors. give me an email or a private msg if you want more info
[Modified by xjoe, 7:39 AM 1/7/2003]
Old Jan 6, 2003 | 11:23 PM
DLB1994's Avatar
i emailed you
trav_89_crx_b7
May 12, 2011 10:37 AM
90si-rex
Sep 13, 2009 09:29 PM
cdescoteaux
Jan 29, 2007 12:13 PM
BigPlansNoMoney
Jan 23, 2005 11:20 PM
Eg692Si
May 17, 2003 10:00 AM
