Help guys, I need a pic's and some mesurement about shifter
Old Jan 5, 2003 | 03:40 PM
kranked91dx's Avatar
Default Help guys, I need a pic's and some mesurement about shifter
HI there!!
I need a pics of the floor of a civic STD, it as to be a std, the pics must be taken near the shifter. And I also want the dimension of the hole in the floor for the shifter. My ca was automatic befor the swap, Now it's std and i just fitted a plate for my shifter, now that plate keep coming some noise from the road and it's pretty anoying. So I decided to weld a plate in place with the correct dimention for the shifter
thank's in advance
kranked91dx
Old Jan 5, 2003 | 07:54 PM
Default Re: Help guys, I need a pic's and some mesurement about shifter (kranked91dx)
Come on people, I know that somebody here got a stripped EF and can mesure the diameter of the hole for the shifter,
any god fellow with a digi cam that can just snap a shot the their floor ??
thank's
Old Jan 6, 2003 | 03:55 AM
Default Re: Help guys, I need a pic's and some mesurement about shifter (efzero.com)
So it is the same hole as an automatic???
for shure I got one more hole in front of it like 3 *6 inch
still want a pic of the floor of a STD EF please
Old Jan 6, 2003 | 04:11 AM
keithv's Avatar
i can get you one of an si. i doubt the std and the si would have a different hole opening...
Old Jan 6, 2003 | 08:07 AM
Default Re: Help guys, I need a pic's and some mesurement about shifter (breaka_1_9)
Nope they are supposed to be the same breaka,
fact are that my car was an automatic befor the swap, and I doubt that auto and std have same hole in floor!!
see ya
kranked
Old Jan 6, 2003 | 10:43 AM
4drEF's Avatar
Keyboard Humorist
From what I have seen, most people cover up the remaining portion of the hole with fiberglass. You could weld in a plate too just like you are saying. All you have to do is make sure that you can still shift properly. You don't need to get it EXACT like the cars that have manual trannies from the factory.
Old Jan 6, 2003 | 01:15 PM
Default Re: Help guys, I need a pic's and some mesurement about shifter (4drEF)
yhea, I got the solution!!,
I'll post pics when I will be done, with my engine code btw, for those incredule poeple that still think that my JDB d15b is BS,
here it goes: I will make a plate in aluminium, slotted in the location of the bolt already drilled in the floor, then, I will make another hole in the plate, same size as the shifter mesurement, then, when I will put it in place, I will only have to place the plate in the desired location!! isn't that a good option??
see ya
kranked!!
Old Jan 6, 2003 | 07:34 PM
I'll use rubber ring, those are 1/16 thick and they cut up noise
yep that what I will do
i'm pretty fixed right now !
kranked!!
Loso_DC2
Aug 26, 2015 04:17 PM
Swaped_EF
Dec 7, 2008 03:27 PM
kaylexty
15
Feb 9, 2008 06:07 AM
jdm Ef-9
28
Oct 23, 2007 10:31 AM
