to those with mini me or summit rpm switch users
Old Jan 5, 2003 | 02:00 PM
stingray2772's Avatar
Default to those with mini me or summit rpm switch users
ok, so i have a mini me set up.. woo hoo yay... also a summit rpm switch and a 12volt auto relay from radio shack to activate vtec... i have yet to experience vtecm for a while i thought i did, but after running wiring into the car and a 12 volt l.e.d i know its not throwing a signal, so ok what do i do now? anything to check? my summit rpm switch and relay aren't even throwing a positive signal to the solenoid, anybody who can help me please??!!
Old Jan 5, 2003 | 05:55 PM
the DR.'s Avatar
Default Re: to those with mini me or summit rpm switch users (stingray2772)
do you have an aftermarket tach? and if so you'll need to wire it differently. also make sure you have power going to the rpm switch first.
Old Jan 5, 2003 | 05:59 PM
Default Re: to those with mini me or summit rpm switch users (SlicedBread)
yep power going to the summit switch, and using stock tach, with input going into the switch from the blue wire on disty
also, does the summit thing have to be inside the vehicle? mine isnt...
[Modified by stingray2772, 3:02 AM 1/6/2003]
Old Jan 6, 2003 | 08:43 AM
rioninja's Avatar
I used to have an MSD rpm switch a while back. I found that the blue rpm wire wasnt enough to trigger the unit, instead hook it directly to the negative connection on the coil.
Also, your summit rpm switch is probably made for an 8 cylinder. I dont know which one you have, but some rpm switches you can set for either 8, 6 or 4 cyl. If your unit is not selectible, your going to have to devide 1/2 the rpm.
For example: for 4400rpm, you would have to set the unit to 2200.
Im pretty sure i've got all that right, its still early
Old Jan 6, 2003 | 10:23 AM
88_SC_CRX_Si's Avatar
New User
Might try flipping "all" the DIPs to the activation position. Then start the engine and rev it a little, you should be able to hear the VTEC noid click, if it's working. At least thats what my Summit did... However, I used the Ground Converter to make it negative for activation tho.
vegaskurt
Sep 29, 2005 07:56 PM
Tinker219
Sep 17, 2004 04:15 AM
jmoney85
May 7, 2004 01:40 PM
satan_srv
Oct 4, 2003 06:37 PM
Jeff_G
Sep 30, 2002 01:35 PM
