87 Accord, Dr. Headlight doesn't work.... need help fast!
Old Jan 5, 2003 | 11:43 AM
Wknd_Warrior's Avatar
Default 87 Accord, Dr. Headlight doesn't work.... need help fast!
I checked the fuses and checked the headlight itself by plugging it in the other side, it works there. Driver's side has no voltage at the plug for high or low beam. Passenger side works fine. Any ideas?
Old Jan 5, 2003 | 01:35 PM
bill-71SS's Avatar
Default Re: 87 Accord, Dr. Headlight doesn't work.... need help fast! (Wknd_Warrior)
follow the harness from the light down where it goes behind the retractor,peel the tape off, you will probably find the wire rubbed thru on the back of the headlight retractor
Old Jan 6, 2003 | 06:15 AM
Stew Pidasso's Avatar
Default Re: 87 Accord, Dr. Headlight doesn't work.... need help fast! (bill-71SS)
Your wires are more than likely broken inside or the plug is corroded. Fo more info see this thread... https://honda-tech.com/zerothread?id=370111
Old Jan 6, 2003 | 08:05 AM
I turns out the wires were broken behind the light from getting snagged. I didn't see it til I gave up on it and put it all back together, and closed the lights... it was right there in front of me the whole time. Thanks for the replies!
cmgoods
Jun 25, 2006 09:44 AM
iNCREDiBLYSLOW
Feb 19, 2006 12:49 PM
PhantomX
Sep 15, 2005 10:44 AM
