Car Died on The Hwy ! Doh
Old Jan 5, 2003 | 07:50 AM
FUP23's Avatar
New User
Default Car Died on The Hwy ! Doh
Com'n back home last night from putting a turbo kit on a DelSol with a B16 ...I was crussing on the hwy home ....car just died everything went dead ..oil and batt light came on. I pull over call some friends and try and check my motor over. Everything looks good. No fuel leaks or plug wires off. Fuel pump is turning on but sounds like Im out of gas . I have to get it towed due to it being 20º outside and No flashlight or tools . 55 bux later Im home and leave it for the night. Wake up with 3 inches of snow on the ground ..I go outside take my first guess and take the dizzy off. My first choice was right!! The rotor screw had came out somehow and was rolling around in the dizzy. Made my day! Makes me wana go be a Honda-Tech ..Thought id share if your car ever dies! Dont tow it. Fix it on the side. A 10 min job cost me 55$. ...
What cuases a rotor screw to come out anyways ? Bumps and vibrations ?
Old Jan 5, 2003 | 08:17 AM
EG8R's Avatar
Default Re: Car Died on The Hwy ! Doh (Devin17)
Wasn't tight enough.... In the 2 years I've worked at Honda I don't think I've ever seen a car come with that problem....
Old Jan 5, 2003 | 08:22 AM
FUP23's Avatar
New User
Default Re: Car Died on The Hwy ! Doh (mr. skelly)
lol....Figues ...Ive heard of it happening on here before but not offten. I tried my best to tighten it down this time AGIAN. You a Master Tech there @ Honda ?
Old Jan 5, 2003 | 08:30 AM
PaImportTuner's Avatar
that happened 2 times with my old 90 hatch then finally the dizzy gave up the 3rd time.
i tried the replacement screw and i tried other screws it always came out sooner or later.
Old Jan 5, 2003 | 08:32 AM
FUP23's Avatar
New User
Default Re: Car Died on The Hwy ! Doh (PaImportTuner)
You try lock tight ? The blue kind maybe .....Im afriad if i used the red stuff it would never ever come out!
Old Jan 5, 2003 | 08:45 AM
zcivicz's Avatar
yeah that happened to me once last summer. i mentioned a couple times on here before trying to help someone else. but it costed me a couple bucks more than yours did cuz the night i towed my car home i had it checked by a local shop when i could've done it myself its all good though. try lock tight it should help
Old Jan 5, 2003 | 09:45 AM
Drumwurks's Avatar
Default Re: Car Died on The Hwy ! Doh (zcivicz)
Blue Locktite works best. Red can help too. Just torquing the hell out of it has yeilded success too, but then you take the chance of stripping the grub screw.
The real trick is to just pop the cap and check it/retighten it during your seasonal (or annual - Depending on your maintenence sched.) tune up.
Old Jan 5, 2003 | 09:48 AM
MADEINIRAQ's Avatar
Default Re: Car Died on The Hwy ! Doh (Drumwurks)
happened to me twice then i learned to put loctite on it... then it happened to my friend.. it will happen to everyone.
96b18c-r
Mar 28, 2009 07:54 PM
ef9rida
Mar 25, 2009 09:15 PM
yeaaaa its slow
Mar 6, 2006 07:20 AM
BallHawk3
Apr 24, 2004 10:57 AM
No More Civic
Dec 30, 2002 08:34 PM
