Gonna change my brake fluid, got a couple of ?s
I'm putting in ATE Superblue and also going to install Speedbleeders . The instructions for them seem pretty simple but I got a couple of questions
1. Is it correct that I should keep the reservoir cap on during the bleeding process, and only removing it to add more fluid?
2. If I fill the reservoir to the max, will there be enough fluid so that I'll be able finish bleeding one corner before having to refill it?
3. Will brake fluid spray out when I remove the stock bleeder screws? (I just wanna be prepared to catch it)
TIA!
TIA!
not necessary, just make sure there is ALWAYS fluid in the reservoir
yes, I've bled ALL 4 CORNERS with a full reservior
Fluid will run out, not spray out. You should remove the stock bleeders first, install the new ones and then flush your system...don't forget to go in the criss-cross order-passengers front, drivers rear, passengers rear, then drivers front
TIA!
TIA!
thanks for the help, but I'm wondering about the bleeding sequence. My helms manual tells me to go front driver, front pass, rear pass then rear driver?
1. You don't need to keep the reservoir cap on
2. Yea, just keep your hood open and check on it every few brake pedal pushes
3. No, it'll drip out in drips first then pour out. Use a brake line clamp on the brake line.
Hope that helps.
Hope that helps.
If you feel more comfortable doing it the helms way, that's fine too
stephaniek123456
Feb 24, 2009 01:23 PM
Kamin
17
Jun 25, 2002 12:38 PM
