FS: ARP Studs,ACL,RC injectors
hey guys i got a new years special for ARP headstuds...$120 shipped
RC 270cc and 370cc only.. i only have one of each ...$265 shipped
ACL bearing set for all honda/acura Main Bearing,Rod bearing,Thrust washers,Assembly lube,Plasticgauge ...$99
i also have alot of used turbo parts.. too many to list..
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Tom i will need bearings and studs for my new D16.
on the same note, can you get D16A1 (88-89 teg) pistons? gasket kit?
seems like i will be dropping some cash with you pretty damn soon. antisways still there?
drop me a PM, or call.
thanks for the patience, BTW
stan
stan
I am interested in the acl bearings... for my d16z6... it uncludes the full bearings for the motor.. and thrust bearings.. also do u have arp studs for teh d16z6?
I just PM'd you but I have a couple of questions that I thought I should post instead...
- These ACL bearing sets are the "Race" series right? not the "DuraGlide"?
- Do they have larger oiling holes then the stock Honda bearing sets?
Thanks
Bryson
Thanks
Bryson
Also, how much would the ACL bearings usually cost?
AP-208-4305 HONDA HEAD STUDS:1.6/D16Y8
Thats the part number for the new bolts that work with D16Y8 motor. Bob Florine at ARP confirmed the authenticity of those bolts through an email to me.
X2
Umm... I'd double and triple check w/ ARP... there are many clowns that work there that give info REAL quick, without checking. ARP may make great hardware, but tech info should be taken with a grain of salt... I recommend you call back and speak w/ someone else to verify (I am not kidding.)
X2
X2
thanks guys for answering the question.! i did verify and the y8 has its own part number.. i dont have those in stock but i will have them on order if anyone needs them
