B17 in a 90 crx dx
Old Jan 4, 2003 | 08:14 PM
Hybrid CRX's Avatar
New User
Default B17 in a 90 crx dx
lets say you just got the long block.
i would need.
cable tranny
wiring
90-93 axles?
what about the dist., and injectors, and ecu?
Old Jan 4, 2003 | 08:15 PM
crx(gator)'s Avatar
Default Re: B17 in a 90 crx dx (Hybrid CRX)
you would need all that, if you use that distributor and fuel injectors not only will you need to do the mpfi swap 1st, but you have to run it obd1 as well...
then you need a mount kit, as well as a shifter...
Old Jan 4, 2003 | 08:28 PM
Hybrid CRX's Avatar
New User
Default Re: B17 in a 90 crx dx (crx "needs fenders" gator)
or,
cant i just use sohc Si injectors, and distributor?
Old Jan 4, 2003 | 08:36 PM
crx(gator)'s Avatar
you would need injectors and a distributor from a 1st gen b16a
it would have to be obd0 and you would use a pr3 or pw0 ecu...
brock316
Jan 11, 2011 09:07 PM
slammedef8
Oct 5, 2005 09:03 AM
p2motorsportcrx
Sep 24, 2005 06:48 PM
ramennoodles
Sep 2, 2004 01:49 PM
REDBARON
Nov 9, 2001 12:52 PM
