Someone Please help diagnose my plugs :(
Old Jan 4, 2003 | 07:32 PM
integranator's Avatar
Default Someone Please help diagnose my plugs :(
They are in order From Cyl 4,3,2,1. There was oil in cyl #2
Old Jan 4, 2003 | 07:38 PM
B18EG6's Avatar
Default Re: Someone Please help diagnose my plugs :( (integranator)
white=lean
as for the oil, check the grommet thing on the bottom of the valve cover that keeps oil away from the plugs...may be leaking
[Modified by B18EG6, 11:39 PM 1/4/2003]
Old Jan 4, 2003 | 07:41 PM
Default Re: Someone Please help diagnose my plugs :( (B18EG6)
the grommet thingy?
edit: I'm not doing any fi-- no nitrous anymore, and when i did use it, i was pig rich.
[Modified by integranator, 4:42 AM 1/5/2003]
Old Jan 4, 2003 | 07:46 PM
B18EG6's Avatar
Here Ill take a pic...stay there, hold on..
There is the part number for the rubber grommets, and the location they go on the underside of the valve cover..
hope that clears up any questions about their function
here is a link to see the parts
http://www.acuraautomotiveparts.net/...DER+HEAD+COVER
[Modified by B18EG6, 11:58 PM 1/4/2003]
Old Jan 4, 2003 | 07:59 PM
ahh, okay. I did a valve adjustment not too long ago, so i'll take her off and see what is up. Also, what did u do to get your valve cover looking like that? And, why would my plugs be indicating that i'm lean, when i'm basically stock.
Old Jan 4, 2003 | 08:20 PM
B18EG6's Avatar
To get my valve cover a little shiny, I first sandblasted it...I then sanded it with 150, 220, 320, 400, 600, 800, and then 1500...then polished it with mothers polish...didnt turn out exactly like i wanted it to though.
As to the plugs..good question, when you say basically stock...what else have you done to it? I dont think this would interfere with anything...but check the gap on your plugs too
Old Jan 4, 2003 | 08:59 PM
arw321's Avatar
Is it just my imagine, or do those plugs look perfectly fine? They might be SLIGHTLY lean, but a tan colour (which they basically appear to be) is optimal.
Any other opinions?
Adam
Old Jan 4, 2003 | 09:27 PM
B18EG6's Avatar
Default Re: Someone Please help diagnose my plugs :( (arw321)
Well perfect plugs should be reddish orange. They arent tooooo lean, just a tad
Old Jan 4, 2003 | 10:39 PM
Hexxboy's Avatar
New User
Old Jan 4, 2003 | 10:40 PM
neo1z's Avatar
yea they arent too bad aj, there is no need to be
Old Jan 5, 2003 | 07:55 AM
Mikey's Avatar
Default Re: Someone Please help diagnose my plugs :( (neo1z)
They look a-okay! I don't think you're too lean...
[Modified by Mikey, 10:55 AM 1/5/2003]
Old Jan 5, 2003 | 08:56 AM
Default Re: Someone Please help diagnose my plugs :( (Mikey)
Thnx guys, Rob, did you engine blow??
Old Jan 5, 2003 | 09:47 AM
ebelp's Avatar
I just had the same problem. I replaced my valve cover gasket and the plug tube gaskets. Total parts costed $21.87 from Acura .
RACEPAK
Apr 9, 2007 03:07 AM
301am
Sep 3, 2004 01:35 AM
mustbenu
Jan 11, 2004 09:48 AM
gooberwolf
Sep 21, 2003 05:17 PM
B18C1 '96 Coupe
Apr 23, 2003 01:50 PM
