A/C fan staying on and draining battery? Anyone else have this problem?
Old Jan 4, 2003 | 07:17 PM
VTEC-DA's Avatar
Default A/C fan staying on and draining battery? Anyone else have this problem?
Correct me if I am wrong, but the driverside fan is the A/C fan. It stays on hours after I turn the car off and drains my battery. 3 jump starts in the last 2 days. Anyway, I am just gonna unplug it since I wont use the A/C for antoerh 3 or 4 months. Anyway, my ? is this. Has anyone else had this problem. What did it turn out to be? The relay in that little black box or something bigger?
Old Jan 5, 2003 | 01:41 AM
VTEC-DA's Avatar
Default Re: A/C fan staying on and draining battery? Anyone else have this problem? (VTEC-DA)
nobody?
Old Jan 5, 2003 | 02:23 AM
jdmotorsports's Avatar
short in the relay. trace it back to the relay and see if that the prob.
Old Jan 5, 2003 | 08:11 AM
b19coupe's Avatar
Default Re: A/C fan staying on and draining battery? Anyone else have this problem? (jdmotorsports)
Yes, I have seen a shorted A/C condenser fan motor relay cause this problem.
Old Jan 6, 2003 | 06:23 AM
blackteg's Avatar
It's a very common pproblem for the G2 Integra. Just replace the relay, its behind the center console next to the back of the radio. I am going to hit you up in a little bit to see if you are still coming by today with this shitty weather. Also, check out http://www.g2ic.com
mark2583
Jan 20, 2010 10:46 AM
spens 91 Ef
11
Apr 14, 2009 05:59 PM
arluk3
Oct 14, 2007 12:05 AM
