Will 91 Teg Front Springs Fit on an 88 Civic DX HB?
Old Jan 4, 2003 | 05:56 PM
tpr's Avatar
tpr
Default Will 91 Teg Front Springs Fit on an 88 Civic DX HB?
As above, I have put a ZC in my DX hatch and it sits a little lower than it used to on the stock DX spring/shocks will the 91 Teg springs be heavier as they share the weight of esentially a ZC motor. I would also like the Teg spring rate as it should be stiffer. Will it work?
Old Jan 4, 2003 | 06:43 PM
Aphrodavid's Avatar
Default Re: Will 91 Teg Front Springs Fit on an 88 Civic DX HB? (tpr)
2nd gen teg springs will fit on 4th gen civic struts and do have a stiffer spring rate, as to how it will sit, i dont know.
Old Jan 4, 2003 | 07:01 PM
Bontke's Avatar
Default Re: Will 91 Teg Front Springs Fit on an 88 Civic DX HB? (DX R)
I have skunk 3rd gen teg springs on my 90 HB. THey are anjustable though. It helped the problem with bottoming out the front with the extra weight of the B18B.
Old Jan 4, 2003 | 07:53 PM
Rywire's Avatar
Default Re: Will 91 Teg Front Springs Fit on an 88 Civic DX HB? (Bontke)
A friend of mine had a zc, with 90-93 teg springs, the front was nice, but the back jacked it up like 4-5 inches. The teg is much heaver in the rear. It was a bad idea. Ryan
Old Jan 4, 2003 | 11:30 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Will 91 Teg Front Springs Fit on an 88 Civic DX HB? (droppedcrxsi)
c'mon now...4-5 inches huh...
Old Jan 4, 2003 | 11:38 PM
iwouldHITit's Avatar
Default Re: Will 91 Teg Front Springs Fit on an 88 Civic DX HB? (Ham'ed Hatch)
so if i buy integra coil overs they should fit my crx too??
Old Jan 5, 2003 | 07:13 AM
primoEF's Avatar
Default Re: Will 91 Teg Front Springs Fit on an 88 Civic DX HB? (iwouldHITit)
should cause they are all the same
Mr_Moos
Suspension & Brakes
Mar 20, 2005 12:36 PM
jeef84
Feb 25, 2005 07:50 AM
Integra187
Mar 31, 2003 06:22 PM
blackDA
Feb 25, 2003 05:38 PM
