I HATE Mobil 1 Super Syn!!!
Old Jan 4, 2003 | 01:40 PM
hYpE-R-29's Avatar
Default I HATE Mobil 1 Super Syn!!!
Just had a oil change couple of months ago, now I need another quart. This thing burn like crazy!!!!..
Im thinking of changing to Castrol SYnthetic, anyone with experience here?..
BTW my car has 42,000 miles..
Thnx
Old Jan 4, 2003 | 01:52 PM
98itR484's Avatar
Default Re: I HATE Mobil 1 Super Syn!!! (hYpE-R-29)
my car runs find on Mobile 1 Super Syn. I check my oil regularly, and i have yet to get to the point where I actually need to put more oil in my car. I dont know much about the Castrol Syn. Oil, hopefully someone will help you out.
Old Jan 4, 2003 | 01:56 PM
yoshi234's Avatar
I shoot brides
25 Year Member
what weight oil j00 using?
yshi - used up .5 qts in 4K miles with 5w30 mobil1, but haven't burnt any since switching to 10w30.
Old Jan 4, 2003 | 02:03 PM
Tommy_Gunns's Avatar
10W30 for summa is coo
5W30 for winta is required
Castrol is
Old Jan 4, 2003 | 02:45 PM
hYpE-R-29's Avatar
Default Re: I HATE Mobil 1 Super Syn!!! (yoshi234)
using 5w-30, should i be thinking of going higher grade with 42k miles...
Old Jan 4, 2003 | 02:49 PM
tjtruong's Avatar
New User
yes if you are burning that much oil, try 10w-30 now and see if it still happens. I use castrol gtx because I'm cheap right now and I have no problems. I have 40,XXX miles also ... BTW, i'm still using 5w-30 with no noticable oil burning yet.
tj
Old Jan 4, 2003 | 02:53 PM
len's Avatar
len
Why's everyone burning oil? I drive 3,000 mile every oil change and the stick is still at the same place.
I use Mobil 1 Super Syn 5W30.
Old Jan 4, 2003 | 03:29 PM
Teepo's Avatar
Default Re: I HATE Mobil 1 Super Syn!!! (len)
I used mobil 1.......burned a quart easily. I went back to conventional oil...castrol GTX 5 30.............no oil loss, not even after days of hard driving
Old Jan 4, 2003 | 04:03 PM
CWESTINAP1's Avatar
Castrol Synthetic works well imo. thats why i use it.
Old Jan 4, 2003 | 04:12 PM
ITR 01-581's Avatar
havoline 5w30 because i get it free I've never had a problem with it
Old Jan 4, 2003 | 04:24 PM
Allstar's Avatar
New User
Default Re: I HATE Mobil 1 Super Syn!!! (ITR1150)
I think everyones motor is different, mine burnt more castrol than mobil 1. I'm using mobil 5-30 and lose about 1/2 a quart every 3k.
Old Jan 4, 2003 | 04:27 PM
Misfit's Avatar
Default Re: I HATE Mobil 1 Super Syn!!! (Allstar)
I personally like to burn oil. I do and i can see it. I also change my oil every 250 miles cause its free.
Old Jan 4, 2003 | 05:18 PM
Nameless RB26's Avatar
Default Re: I HATE Mobil 1 Super Syn!!! (MISFIT)
I burn no supersyn.. but I'm thinking of switching to 10w30 supersyn for the hell of it..
Old Jan 4, 2003 | 09:39 PM
514_type R's Avatar
Default Re: I HATE Mobil 1 Super Syn!!! (Nameless)
ive also used mobil 1 and I had to add some oil every 500miles. Ended up bieng my piston rings. You should check your piston rings, but first switch oil and if the problem is still there, its your rings
Old Jan 4, 2003 | 09:45 PM
xjohnx's Avatar
Hrm, i'm using Mobil 1 5w30, 38k on the car, burned about .5 quart in the last 1000 miles, what do y'all suggest i do?
FULLTHROTTLE's Avatar
Default Re: I HATE Mobil 1 Super Syn!!! (514_type R)
If you drive it hard it can and will burn up to a quart avery 1000 miles.
Old Jan 4, 2003 | 10:17 PM
Todd00's Avatar
I said I don't want a title!
Why not just mix oils? Use 2 qts of Mobil full syn and then 2 qts of normal Mobil. Works well together. I do this for my daily driver to have the benefit of both.
Note that the "blends" are sometimes only 10% syn.
Old Jan 4, 2003 | 11:00 PM
Dirt's Avatar
Default Re: I HATE Mobil 1 Super Syn!!! (xjohnx)
Try M1 10w30.
Old Jan 4, 2003 | 11:05 PM
Dirt's Avatar
Default Re: I HATE Mobil 1 Super Syn!!! (Todd00)
Most OTC synthetic blends are only 5-10% synthetic. Just enough for them to call it a 'blend'. I use Shaeffer 10w30 (a synthetic blend) but it is 30-35% synthetic.
Old Jan 4, 2003 | 11:41 PM
oz#227's Avatar
New User
Quote:- " Why not just mix oils? Use 2 qts of Mobil full syn and then 2 qts of normal Mobil. Works well together. I do this for my daily driver to have the benefit of both.
Note that the "blends" are sometimes only 10% syn. Quote.
I was told with this 0W-40 Oil not to mix-it with ANYTHING ELSE, they me a couple of litres in a spare container for top-ups.
I CHECK MY OIL EVERY 2 or 3 TANKS of FUEL. Every 1000-1500kms- No suprises.
I've been running 0W-40 Mobil 1 Super Synth since 10,000kms. Its was run on Good dino Oil for the 10,000 (2 x changes, 1st-2,000kms 2nd-5,000kms ) 3rd change -10,000kms 0W-40. I check the Oil regularly, but never needs any, unless I'm at the track. VTEC All Day and it only used a tiny amount (Less than 100ml).
Now it's got just over 55,000kms and still going Strong.
Not all motors are the same, Not all car are well run-in. That's good reason to get a car brand new and run-it-in the way you want. It's not as important with modern engines. But just look at this thread, If All ITR's were the same, You guys could use thin Super Synth as well.
Why do Car Manufacturers now extend Oil change periods, while still using oil that's supposed to be changed after 5,000kms, being left in for sometimes 20,000Kms. The result - A fogged-out motor way before time. Just to make the car seem cheaper to service. Big deal - Your up for a new car sooner - That's Why!!
Just my 2c - Later.
Old Jan 5, 2003 | 12:08 AM
underrated99si's Avatar
Aftermarket intake filters. Most people I have scene dont realy change and re oil them as often as they should and filters like K&N althow they flow more air also flow small dirt particales in as well and the dirtyier the filter is the worse it is so fine dirt particales slowly cause scratches in the cylinder walls causing oil to find its way into the combustion chamber and causing it to be burnt off.
I have seen this more times then I would like to Plus my mechanic (3 time certified master tech bla bla bla) has shown it to me over 50 times mostly ricer stunners who dont understand that u must change filter. NOT to call anybody on hear a stunna but I have scene a couple of HT'ers with filters that were more black then red . If it does not make sence then try this take off your k&n filter sometime hold it up to the sun and look inside and you will see alot of little pin like holes that u see the sun light perfectly threw so if you can see threw it then surely dirt can come threw ( I guess that is how they flwo 50% more air ) I personaly run a COMPTECH filter cause it is a performance tipe but has a hell of alot more filter element than any K&N and I will give up the 1hp for longerlasting motor
JUST MY .02
Old Jan 5, 2003 | 12:29 AM
oz#227's Avatar
New User
Default Re: I HATE Mobil 1 Super Syn!!! (underrated99si)
Couldn't agree more.... I change all the Filter ever 10,000Kms, Air, Oil & Fuel.
I can't justify putting new oil thur an Old filter.
Old Jan 5, 2003 | 03:24 AM
rodimus's Avatar
Default Re: I HATE Mobil 1 Super Syn!!! (Tommy_Gunns)
Castrol is
winta? how about so cali...10W30 all year long
Old Jan 5, 2003 | 04:26 AM
SoCal ITR's Avatar
Default Re: I HATE Mobil 1 Super Syn!!! (98itR484)
Old Jan 5, 2003 | 07:02 AM
Rory Breaker's Avatar
Default Re: I HATE Mobil 1 Super Syn!!! (SoCal ITR)
I always used Mobil Syn 10w30, switched to 5w30 and ate it up...
Switched back to 10w30 with no problems.
