intake, gas saver?
Old Jan 4, 2003 | 11:15 AM
slowaccord01's Avatar
Default intake, gas saver?
I have an 01 accord coupe v6 and I was wondering how much hp will i gain (probably not much) LoLz, if i added a ram aem intake and does it really save gas?
oh and one more thing, sorry if this is off topic but i was hacked!!! LoLZ someone changed my password so i couldn't get into this site and post, that was very wrong.
well i guess that is it for now thanks for replying
Old Jan 4, 2003 | 11:38 AM
Nick M's Avatar
Default Re: intake, gas saver? (01accordcpe)
You will definitely free up around 10hp with an intake on a V6 accord.
What kind of mpg do u get now? Keep an eye on it after the intake is installed. Its not brain surgery. Depends alot on your driving style.
DrunkNRacer's Avatar
An Cold Air Intake will definetely help that v6 breathe. I dont exactly what gains you will see.. somewhere around 8hp? I dont know. But there is no doubt it will increase your gas mileage.. not a dramatic change.. but definetly go for it. My friend loves his AEM C.A.I on his accord v6.
[Modified by SlowAssAccord, 3:39 PM 1/4/2003]
iam7head's Avatar
about whp3 you'll be getting.
alittle bit better on gas mileage if you dont gun it down all the way
all the time.
my friend who drving a exv6 00' had a short ram too.
it's mucho loud for some reason.
[Modified by iam7head, 8:41 PM 1/4/2003]
Old Jan 4, 2003 | 12:05 PM
Razor's Avatar
Default Re: intake, gas saver? (iam7head)
yeah it seems the j30 gains more than the 4 cylinders when it comes to bolt ons, 3-4 whp sounds about right. make sure you reset your ecu though, if you don't you will get crappy performance and mileage, although the ecu will adjust itself after a while but its better to do it manually and immediately.
to reset the ecu, just unplug the negative on the battery for 5 min, connect the battery, start it up and let it idle for 5-7 minutes, and turn it off. the next time you start your car your ecu will be fully reset. make sure to have all appliances off and dont rev the car.
Old Jan 4, 2003 | 12:09 PM
one clean ride's Avatar
Default Re: intake, gas saver? (Razor)
i saw a dyno for a v6 6th gen that gained 8 whp from a aem short ram...this was from a year ago.
Old Jan 4, 2003 | 12:13 PM
so should i get a CAI or ram aem intake? and if i do install it will it weaken my transmission or engine? cause thats what i have heard, is it true?
I also have something off topic to ask, im planing to get new tires for my accord and was wondering what brand of tires is best and what type of rims match my silver accord.
thanks.
Old Jan 4, 2003 | 03:55 PM
cyrixvsp2's Avatar
it won't hurt your engine. your lead food is what will hurt the engine. you are only letting it breathe more so don't worry about engine damage.
about the tires, i'm strait falken tires all the way. love em
Old Jan 4, 2003 | 03:56 PM
EuRoBrO's Avatar
A CAI will not harm any part of your motor or transmission. The only thing that could go wrong is that you run into a big pile of water and suck it up. Just be careful.
Old Jan 4, 2003 | 04:03 PM
v6illusion's Avatar
Only problem with an intake on the v6 is that it sounds so nice you can't keep your foot off the gas so you end up getting worse gas milage.
Old Jan 4, 2003 | 06:12 PM
Bubble Gum Jr.'s Avatar
CAI would be better to get than Short Ram, it would have better gains since the CAI uses cold air from outside of the engine where Short Ram uses air from inside of the engine which is generally pretty warm/hot. The only thing you have to worry about is cutting into your wheelbase to install the CAI and may be water/snow other junk getting into it. But that's not really a huge thing to worry about since the hole can easily be filled and isn't too large, plus if you put a sufficient cover near your filter or a mud flap than you should have no worries.
Dave
Old Jan 4, 2003 | 06:37 PM
iam7head's Avatar
Default Re: intake, gas saver? (Bubble Gum Jr.)
for 01-02 accord coupe, the spot is perfect for CAI.
there's a big *** vent right infront of the filter
I have a ghetto rag intake on my legend. it sounds like a mustang.
20ls01
Apr 9, 2009 08:28 PM
v4lu3s
Jan 29, 2006 03:22 PM
powered_by_greddy
Jan 28, 2006 09:14 AM
blackriceman
Apr 7, 2005 07:34 PM
OdysseyHF
Feb 19, 2004 09:46 PM
