Just Got VIS Carbon Fiber Hood
Old Jan 3, 2003 | 11:41 PM
Denny's Avatar
Default Just Got VIS Carbon Fiber Hood
Do I need Hood Pins?
Old Jan 3, 2003 | 11:45 PM
jonas's Avatar
Default Re: Just Got VIS Carbon Fiber Hood (TypeR882)
could you please weigh both your stock hood and the VIS CF hood so we can get the truth about the weight savings.
Old Jan 3, 2003 | 11:51 PM
itr1244's Avatar
you better have it..
Old Jan 4, 2003 | 12:07 AM
lucas569's Avatar
need no, recommend yes.
Old Jan 4, 2003 | 12:12 AM
SoCal ITR's Avatar
Default Re: Just Got VIS Carbon Fiber Hood (lucas569)
It helps if you attach the rubber lining that was on the front of your old hood... hood pins aren't necessary, but it's still a good idea.
[Modified by SoCal ITR, 1:50 AM 1/4/2003]
Old Jan 4, 2003 | 12:21 AM
CWESTINAP1's Avatar
Default Re: Just Got VIS Carbon Fiber Hood (SoCal ITR)
eh... no need.
Old Jan 4, 2003 | 02:45 AM
Type R's Avatar
Default Re: Just Got VIS Carbon Fiber Hood (CWESTINDC2)
eh... no need.
yea that hood is pretty heavy. Weigh both hoods and see how much weight you saved
Old Jan 4, 2003 | 03:21 AM
CWESTINAP1's Avatar
Default Re: Just Got VIS Carbon Fiber Hood (Type R)
better then those flimsy paper thin hoods imo.
Old Jan 4, 2003 | 04:30 AM
civic23g's Avatar
I have a VIS hood on my civic,don't need hood pins but it isn't a bad idea. It was a lot ligher than my stock one. And yes the little rubber stock piece helps the fitment look cleaner.
Old Jan 4, 2003 | 07:21 AM
Rory Breaker's Avatar
BTW VIS Integra Hood, according to VIS = 19lbs.
I dont remember the stock weight...mid 30's? I said it before, CF hoods are DEFINITELY not performance modifications!
oz#227's Avatar
New User
Default Re: Just Got VIS Carbon Fiber Hood (civic23g)
Don't worry about the looks. The rubber stops the wind getting under the hood, Lifting it and smashing your wind shield and roof.
Hood pins on any CF Hood.
Later.
Old Jan 4, 2003 | 08:58 AM
Arsenal's Avatar
Default Re: Just Got VIS Carbon Fiber Hood (oz#227)
I had pins on my CBF hood before i left for U.K and while I was gone I had a private guy re-condition everything, ie Lacquer, lots of clear coat. when I got back the hood pins were no longer on so I just drove down the road to my house. Happened to drive a little fatser and around 65 it popped up and smash into me. Scared the crap out of me so yes definetly hood pins. There was no rubber strip on the underside but the fitment was contact with bumper.
Old Jan 4, 2003 | 09:57 AM
Dr Pooface's Avatar
Default Re: Just Got VIS Carbon Fiber Hood (newgsrdriver)
VIS CF hoods are heavier than most.
Old Jan 4, 2003 | 10:31 AM
brinks's Avatar
You might be able to gt away not using them, but make sure that you attatch all of the rubber seals securley. When I got my vis for my g2, it did not have the holes for the secondary hood rubber. i had to drill them myself. And the holes for the primary hood rubber werent in very goos shape either, I had to drill them out a bit too. Take the time to turn the hood over and make sure that all of the stock hardware is transferred over.
Old Jan 4, 2003 | 11:08 AM
Default Re: Just Got VIS Carbon Fiber Hood (Dr Pooface)
Your average CF hood is around 13-15lbs (depending on quality of construction...some of the cheapies are obviously lighter), so youre looking at an extra 5lbs with the VIS hood. Again...$400+ for a 15lbs weight savings is definitely not under the "bang for your buck" category
Old Jan 4, 2003 | 11:09 AM
Rob :190:'s Avatar
gotta pay to play
Old Jan 4, 2003 | 12:02 PM
Padawan's Avatar
Darth ModerVader
Aside from removing certain parts all-together (e.g., power steering, airbags, interior), 15 lbs. doesn't come much more cheaply than that.
Old Jan 4, 2003 | 12:13 PM
98cwitr's Avatar
Default Re: Just Got VIS Carbon Fiber Hood (Padawan)
personally if the hood latches fine then i wouldnt get them. My mb autosport hood didnt latch so i had to cut the latch off and install hood pins (this was on my celica)
Old Jan 4, 2003 | 01:51 PM
Type R's Avatar
FI makes great hoods and they are alot lighter then VIS. Quality of the FI hoods are awesome. I just saw a friends FI hood last night and its
cf hood for weight savings
cf hood for looks
[Modified by Type R, 2:52 PM 1/4/2003]
Old Jan 4, 2003 | 05:14 PM
Denny's Avatar
I got it for cheap, i picked up the hood for 250 flat. So $250 for 15 pounds is good enough for me
Old Jan 4, 2003 | 05:40 PM
tony4311's Avatar
wow. Good find
Old Jan 4, 2003 | 08:02 PM
Type R's Avatar
Sweet deal
vinceg143
Apr 29, 2009 05:49 PM
andylauiii
Aug 6, 2004 01:55 PM
steronz
Feb 18, 2004 12:58 PM
VintegraGSR96
Sep 5, 2003 08:49 AM
WTypeRogerX
Feb 12, 2003 08:15 AM
