Pwo ecu o2 sensors question (did the search)
Old Jan 3, 2003 | 10:22 PM
Rywire's Avatar
Default Pwo ecu o2 sensors question (did the search)
Hi, I had a pr3 ecu, and switched to a pwo, now I have a code #2. I heard the pwo needs only one o2. I disconnected the o2, and reset the computer, and I still have the code. Could I have just had a o2 sensor go out at the exact time I put in the other computer? With a pwo does it have to have only 1 o2, or can I run 2? Because the hasport harness always has a extra wire for the second o2, and if it was for a car with a pwo, they would make a option, with or without second o2 sensor. As you can see I am kinda confused, help me. I hope you understand this. Thanks Ryan
Old Jan 3, 2003 | 10:37 PM
Rywire's Avatar
Default Re: Pwo ecu o2 sensors question (droppedcrxsi)
OK, I just read that both computers need 2 o2's. So, I need some new o2 sensors? Its just weird that they went bad at that time. Ryan
Old Jan 3, 2003 | 11:03 PM
Vinceg99's Avatar
Maybe it was already bad but your ECU didnt pick it up?? Maybe something wrong with the old ECU??
Old Jan 4, 2003 | 08:53 AM
Rywire's Avatar
Default Re: Pwo ecu o2 sensors question (Vinceg99)
Hmm, yea, both possible. Is is bad to drive it like this? Ryan
Will my 89 si o2 work if I splice it in for the one with the opposite connection? And the other o2 will be plug and play, right. Thanks Ryan
Old Jan 4, 2003 | 09:53 PM
Rywire's Avatar
bump
HONDA RR
Sep 16, 2005 03:53 PM
red_crx
Nov 26, 2004 04:38 AM
Shakes
Apr 28, 2004 08:45 PM
Qwikrex
Jul 31, 2002 09:53 PM
