Turbos for SH
Old Jan 3, 2003 | 07:51 PM
JsrEvo's Avatar
Default Turbos for SH
I have a 99 SH and going to get turbo for it but I cant and dont know which is the best for the SH.. I know that SH engine is a little different from the base model. Also, which front bumper has the biggest middle space for max flow of air into the intercooler?
Old Jan 3, 2003 | 07:58 PM
sslude's Avatar
Default Re: Turbos for SH (JsrEvo)
the engines arent different at all. look at the block where it has hte engine code if it say something other than h22a4 (for my year at least) then it different, but if it is an h22 then its the same. you have to remember that pushing an SH over 280whp, you have to throw away your ATTS, therefore making it a non SH. becasue of so much power, it disables tha ATTS system
Old Jan 3, 2003 | 08:05 PM
JsrEvo's Avatar
Default Re: Turbos for SH (sslude)
Manufacturers do make the distinction between the two so obviously there is a difference. But still..which turbos are more suited more SH??
Old Jan 3, 2003 | 09:49 PM
KevinOhlin's Avatar
yes their is a diffrence between the two cars ATTS
are you looking at tubro kits or custum.
if you are looking for a kit look at the fmax kit alittle pricey but its a good kit.
Old Jan 3, 2003 | 09:59 PM
sslude's Avatar
just dont get too much boost is all i am saying, unless you dont want ATTS
Old Jan 4, 2003 | 12:13 AM
JsrEvo's Avatar
Default Re: Turbos for SH (KevinOhlin)
how much boost am I looking at?
Old Jan 5, 2003 | 02:32 PM
2000TypeSh's Avatar
Half correct. The block and the head aren't different but the tranny is. If you ever get under a SH the ATTS is the big *** hole that gets in your way.
This is definately true. But if you are going over 280 then you will probably get rid of the piggy backs and go standalone anyways. Therefore no stock ecu = no ATTS.
Old Jan 5, 2003 | 02:34 PM
2000TypeSh's Avatar
Default Re: Turbos for SH (2000TypeSh)
As far as picking a kit I'd go with FMAX also (Oh wait I already did).
They do have a clean kit and basically everything you need to get started for 7-8 pounds of boost.
R3JEKT
Dec 9, 2007 10:10 PM
kelvinchau125
Jun 20, 2007 10:59 AM
fauxhawkid
Jan 19, 2007 09:56 AM
blueradii
Jul 13, 2004 09:49 AM
speed junk1e
May 20, 2004 05:47 AM
