help on head work please
Old Jan 3, 2003 | 03:02 PM
ThatRicerDaniel's Avatar
Default help on head work please
i am running a 91 LS and am about to put some crower dual valve springs and Ti retainers in.. is it hard? i have never done this. do i need any special tools? any tips/ tricks would be helpful . thanks guys.
Old Jan 3, 2003 | 05:02 PM
CRX Si's Avatar
Default Re: help on head work please (NitrousDreamz)
you need a torque wrench, and the torque specs (someone here can prolly spit it out with out even thinking about it)...
Old Jan 3, 2003 | 05:14 PM
SiR831's Avatar
Default Dan
have you hit up cylinder heads unlimitied in salinas?
Old Jan 3, 2003 | 06:35 PM
altoid's Avatar
Default Re: Dan (SiR831)
you'll also need a feeler gauge to get the correct tolerances for the rocker on the valve. In case you don't know what it is its like thin pieces of metal at a certain thickness and you just slide it down and tighten or loosen until appropriate tolerance is obtained.
Old Jan 4, 2003 | 12:58 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
I would not recomend you doing the job if this is your first time at it.
For the spring removal. you will need a valve spring compressor.
there is just too much to do for someone w/o experience and way too many ways to screw it up. I have done it a bunch of times and replacing the valve springs is a full days work. you have to work on one cylinder at a time so you don't accidentally drop a valve into the cylinder. plug all possible holes a keeper could fall into, etc.
monster_c
Jun 5, 2012 12:32 PM
WONG FRIED RICE
Dec 7, 2008 04:05 PM
prolifikproficy
Jun 16, 2008 09:04 AM
ITRfaithful
Feb 19, 2003 04:05 PM
erniecars
Mar 31, 2002 12:00 PM
