trunk leaks in an EK9
Old Jan 3, 2003 | 09:14 AM
NiraCivicJDM's Avatar
Default trunk leaks in an EK9
Any body have any idea's why my trunk leaks up water so damn bad ? is it because of my ride height? and i live in portland oregon, i take a look at it and thing is flooded with water i am going crazy i tryed to seal it up with silicone glue but that didnt work i couldnt figure where the water is coming in from any clues ? what i did i just tryed sealing everything little hole or where honda had their seals at but yeah help me out
Old Jan 3, 2003 | 09:54 AM
euclid's Avatar
Default Re: trunk leaks in an EK9 (NiraCivicJDM)
i have a 94 coupe, and on the drivers side there is like an air vent under the rear bumper, it could be this. and make sure all the holes in the floor are properly capped and your rubber molding around the trink lid is there/intact. good luck
Old Jan 3, 2003 | 10:12 AM
tominos's Avatar
last weekend looked at my trunk too. it had an inch deep of water, just used the vacuum to suck it all out. i can't find the leak either. it's been a couple days and noo sign of water in there yet though. tell me if you find where it's coming from
Old Jan 3, 2003 | 10:16 AM
SergEK's Avatar
EK9 with a trunk huh? lol
Check your tail lenses and make sure all the seals are on tight, I had a loose tail lamp (dont ask me how it got loose) and I had moisture coming through that into my rear hatch area.
Good luck
Old Jan 3, 2003 | 10:29 AM
intezn's Avatar
Default Re: trunk leaks in an EK9 (SergEK)
what about a 99 4dr? EWhatever I forgot............
is leaking like heck and I couldn't find where, but I see it drips near the right tail lense.
Old Jan 3, 2003 | 10:39 AM
tominos's Avatar
mine is 97 coupe. and it's not leaking from the lights.
Old Jan 3, 2003 | 10:54 AM
98coupe#2's Avatar
From: 0.03 posts per day on average, 190 days, 5 posts
Default Re: trunk leaks in an EK9 (tominos)
Mine leaks too
Old Jan 3, 2003 | 12:11 PM
jdmekcivic2eg's Avatar
Default Re: trunk leaks in an EK9 (myFASTek)
98ek hb.. yep.. my trunk leaks too..
also the window tracks are messed up too.. i think i got a lemon..
[Modified by jdmekcivic, 1:12 PM 1/3/2003]
Old Jan 3, 2003 | 12:16 PM
pkek's Avatar
Default Re: trunk leaks in an EK9 (jdmekcivic)
u imported a CTR?
Old Jan 3, 2003 | 12:32 PM
666hatch's Avatar
Default Re: trunk leaks in an EK9 (pkek)
im on my third civic a 90, a 2000, and now a 92 and everyone has leaked.
Old Jan 3, 2003 | 02:01 PM
gamby's Avatar
Default Re: trunk leaks in an EK9 (666hatch)
n00b--before someone finds a way to punch you in the mouth on the internet--
An EK9 is a Japan/Europe-only Civic Type R hatch that was built between 98 and 2000. That is the only 6th gen Civic that is an EK9.
May god have mercy on your soul.
Old Jan 3, 2003 | 02:08 PM
Airbag Club's Avatar
Default Re: trunk leaks in an EK9 (gamby)
my 99 civic hb also leaks water. i keep on hearing water swooshing around, and one day i looked in my spare tire area and there was about an inch of water. good thing i have stripped interior, so no harm done.
Old Jan 3, 2003 | 02:21 PM
goldffronts's Avatar
Default Re: trunk leaks in an EK9 (Airbag Club)
the seals behind the taillights are where mine used to leak. .apparently they revised them in '99 (minewas a "98 hatch )my lights were always full of water too... THATS where it came through i guess..
Old Jan 3, 2003 | 05:41 PM
hatch101's Avatar
damnitt IM NOT THE ONLY ONE!! man i have been trying to figure that crap out for a long time!! grrrr....
Old Jan 3, 2003 | 06:46 PM
thelucysong's Avatar
Default Re: trunk leaks in an EK9 (hatch101)
I have a 97 coupe and the right side of my trunk leaks like crap.
Old Jan 3, 2003 | 06:48 PM
migs's Avatar
Default Re: trunk leaks in an EK9 (xthisfallx)
Has your car even been in an accident?
Old Jan 3, 2003 | 06:57 PM
fastwanabe's Avatar
hhahahahahahahahahah.... good one
Old Jan 3, 2003 | 07:20 PM
broke1's Avatar
Default Re: trunk leaks in an EK9 (fastwanabe)
i have a 99 coupe and no leaks....yet. two of my friends hatchbacks (96 and 00) did leak.
Old Jan 3, 2003 | 07:51 PM
tominos's Avatar
Default Re: trunk leaks in an EK9 (broke1)
damn trunk leaks still, vacuumed out all the water like 4 days ago, now it's about 1/2 inch deep again. i've looked and can't see where it leaks from still.
Old Jan 3, 2003 | 08:47 PM
nerdsports's Avatar
my CRX had a leak... and i ended up fixing the tail light gasket and it helped.
anywho. i'd say remove all ur panels from the rear and clean the trunk up real clean and maybe u'll see some marks of water seeping in.....
IDEA: get in ur trunk area. after everything is removed. and get a friend to hose ur car.... leave the hose running about 5minutes in several spots. maybe u'll find it.... GOOD LUCK!!
Old Jan 3, 2003 | 10:43 PM
IWearMyKswiss's Avatar
New User
you dont have a lemon,..you are experiencing what most 6th gen hatchback owners go through (coupes experience the window tracks problem too),.. about the leak,..its coming from the taillights,..about the window tracks,..you have to bend back the "regulators" or atleast i think thats what htey are called,...its the rail that goes up and down next to the mirror,...i bent mine back straight and it doesnt go back off track anymore,..but it doesnt perform like it use to,..if you have manual windows,..do not torque the window when you are rolling it up all the way,..once it is all the way up DO NOT give it that extra little turn,..this is what causes the rails to bend
Old Jan 4, 2003 | 12:11 AM
naw bro, its not a Ek9 i just call it an EK9 because i have a CTR motor in it USDM chassi
Old Jan 4, 2003 | 12:23 AM
Viorent GRIP!'s Avatar
Default Re: trunk leaks in an EK9 (intezn)
Has your car been hit from the back before? The bodyshop may have removed the drain lines the run along the inside of the car.
Old Jan 4, 2003 | 12:28 AM
intezn's Avatar
Default Re: trunk leaks in an EK9 (Viorent GRIP!)
yes, 2 time in the rear
and where is the drain lines you are talking about that is inside the car?
when water drips, it come out from somewhere inside the trunk behind the right lenses.
Old Jan 4, 2003 | 12:34 AM
Im not exactly sure where they are on 4doors, behind all that carpeting in the trunk there should have been like a clear hose, that's the drain, most of the time bodyshops don't bother putting that back in.
