will si injectors fit d16y8 mani?
Old Jan 3, 2003 | 06:58 AM
91hondacrx's Avatar
Default will si injectors fit d16y8 mani?
Anybody know? If i am goin to use a d16y8 mani, is there a way that i could use the y8 injectors, but still have it work corrctly(not have a lean or rich mixture)? If i did do this would i need to adjust the timing in order to make everything work wonderful? Any thoughts. Any help would be greatly appreciated, oh i am doing the mpfi conversion. I have the y8 mani and i figured i would get a lil more air into the chamber for some power. Anyone know how well this works?
Thanks,
Matt
Old Jan 3, 2003 | 07:05 AM
zCivic's Avatar
Default Re: will si injectors fit d16y8 mani? (91hondacrx)
I would suggest you 88-91 SI injectors. The Y8's flow the same but there OBD2 and use different harness plugs. This means would have to rewire and remove injector resistor box also. Just swap the squirters
91hondacrx's Avatar
Default Re: will si injectors fit d16y8 mani? (zCivic)
do you know if they fit right in?
Old Jan 3, 2003 | 08:28 AM
zCivic's Avatar
Yeah they go right in no problems. I have them in mine right now....
Old Jan 3, 2003 | 11:10 AM
chillincivic's Avatar
I have them on my y8 mani also. fit like a charm
Old Jan 3, 2003 | 12:01 PM
91hondacrx's Avatar
Default Re: will si injectors fit d16y8 mani? (chillincivic)
Could you guys tell me or how you figured out how to hook up the y8 mani running on the a6? I have heard the vacuum hoses were a little different but i do not have any other info besides that. Any help would be appreciated.
Thanks,
Matt
Old Jan 3, 2003 | 12:15 PM
zCivic's Avatar
I ran mine on a Z6. I by passed the coolant lines thru the intake manifold and throttle body completly. T them off from one side of the block to the other 2 at the other end. Vacumn lines are the same, I used the Y8 map sensor which got rid of that hose and the large one on the front goes to the Canistor on the pass firewall. FPR still goes to the same place. You may have one in the back which work for the cruse just plug it. Have any issues IM will help if can
GavinVTEC
Jul 17, 2012 04:29 PM
89si203
30
Sep 12, 2011 08:16 PM
eddie422
Mar 28, 2011 02:27 PM
Ser1N
12
Dec 3, 2007 09:36 AM
senn1n103
May 15, 2006 09:13 AM
