Oil Leak what do u think it is?
Old Jan 3, 2003 | 01:27 AM
crxgurlllll's Avatar
Default Oil Leak what do u think it is?
Had some cams installed this past weekend and ive been driving the car daily since then and no oil leaks.(i dont think its related to the cam install)
Today i was driving the car hard and decided to check under the car and hood when i got home.....
Immediately there was about a tablespoon of oil on the ground and oil all over the a/c bracket...it appears to be comming from where the head and block meet.....but im not sure..... opinions welcome...
Old Jan 3, 2003 | 02:05 AM
1st-hybrid's Avatar
Default Re: Oil Leak what do u think it is? (I Want An Si)
Was everything torqued to specs when it was put back together??
Thats what I would look into first, if there is nothing obvious.
Old Jan 3, 2003 | 04:37 AM
keithv's Avatar
Default Re: Oil Leak what do u think it is? (1st-hybrid)
make sure its not coming from the valve cover as that seems to leak sometimes.
Old Jan 3, 2003 | 05:43 AM
primoEF's Avatar
Default Re: Oil Leak what do u think it is? (breaka_1_9)
check the cam seal and valve cover
Old Jan 3, 2003 | 06:14 AM
XEF-9X's Avatar
Default Re: Oil Leak what do u think it is? (EFDog)
i agree with ef dog cam seal yo!
Old Jan 3, 2003 | 06:51 AM
Mugen Dom's Avatar
well it cant leak from in between the block and head so its gotta be like they said a cam seal or valvecover seal
Old Jan 3, 2003 | 10:54 AM
FUP23's Avatar
New User
Default Re: Oil Leak what do u think it is? (JdMB16Ahatch)
It looks to be leaking on the AC so the valve cover gasket would be my choice sence the cam seals are on the left side of the motor .
Old Jan 3, 2003 | 12:09 PM
rice_classic's Avatar
Default Re: Oil Leak what do u think it is? (Devin17)
Cam seal unless you didn't torque your head properly or re-used your head gasket.
Nonetheless my vote goes to the cam seal.
Old Jan 3, 2003 | 12:48 PM
EL Vap133's Avatar
Default Re: Oil Leak what do u think it is? (crxgurlllll)
yeah, when I saw the cam seals you purchased, they looked weak! So I agree on the cam seals...
Old Jan 3, 2003 | 01:16 PM
gtpilot's Avatar
If they did not clean the saddle corners at each and of the head and the valve cover gasket, then put Honda Bond on all four of the corners where they meet the saddles...dollars to donuts it is the valve cover gasket that is leaking.
Kirk
Old Jan 3, 2003 | 01:24 PM
TheShocker's Avatar
check the cam seal
Old Jan 3, 2003 | 02:00 PM
Default Re: Oil Leak what do u think it is? (TheShocker)
Old Jan 3, 2003 | 02:21 PM
altoid's Avatar
this same thing happened when tortex got his si head, it didn't have a cam seal...it lost something like a quart on his way to school. Thats unwanted oil leakage coming from the seal, buy a new oem seal
[Modified by altoid, 6:22 PM 1/3/2003]
Old Jan 3, 2003 | 05:37 PM
Mugen Dom's Avatar
looks to be the cam seal if those pics are ur cam seal.....
Old Jan 3, 2003 | 06:38 PM
bartek_b's Avatar
hey, crxgurlllll, it might be your cam seals, or check and make sure your valve cover is bolted on good.
Old Jan 5, 2003 | 06:25 PM
2k2silvertype-s's Avatar
Default Re: Oil Leak what do u think it is? (mugen85r)
definately check your cam seal. although here is a weird situation. i had my CTR cams put in not to long ago. we took it for a spin and oil was coming out. we assumed it was the cam seal and it ended up being the vtec solenoid gasket. but i still think it's the cam seal.
Old Jan 5, 2003 | 06:44 PM
slow ride 74's Avatar
there is a special tool for the cam seals they are leaking get some now ones from honda and dont forget the honda-bond on the valve cover gasket trust me it works like a charm good luck
mouab18c1
Jun 26, 2009 05:01 AM
Nine0DA7
Apr 20, 2008 08:12 PM
acro_acura94
Jan 18, 2007 06:15 PM
Gonzob16
Nov 6, 2006 07:55 PM
SkoundrelUSA
11
Feb 14, 2006 10:06 AM
