anyone doing your brake swap get your rotors here.
i'm probably getting mine thru mkteller (handle is something like that) who sells nopi prices. are you guys reusing your hub/wheel bearings? or replacing them? if you are, where are you getting the replacements?
but if ur gonna be replacing ur rotors, y not just get cross-drilled, and pay the extra money for them? thats wat i would do, but i got 4 rotors to replace on my accord, so...it'll cost a pretty penny.
crossed drilled on a street car is ****, not the ****, **** as in worthless...
you think were all doing brake swaps and using brembo blanks because were cheap idiots? not slotted and crossed drilled is worthless
[Modified by ArchAngel Sabastian, 6:29 PM 1/3/2003]
no you didnt, but your suggestion was kinda just an on the fly your idea/opinion type thing and its actually false so when you post a suggestion that goes against all the posted FACT on the board and there have been countless topics about the AV6/legend brake upgrade and using blank rotors. i simply thought you had to be say that we were all flaming idiots for posting all this time about blank rotors when in fact slotted rotors are far far superior....
ok....well, i didn't kno, i'm new to the board. on the subject, are u saying that slotted brakes are better then cross drilled, or slotted and cross drilled brakes r not as good as blanks? thanks.
thanks for the info....then would wats the point of replacing the stock ones? cuz those r blanks. i mean, obviously, Brembo is doing something right, cuz there on lots of cars...do they not heat up as much as stock discs or wat? thanks for the info.
on that site rotors are listed 90-94 for accords and 95-97, why is this? is this the right classification?
you said something about the stock brakes i think and we change over to the AV6 rotors/calipers because they are larger, the front accord brakes are simply to small in my opinion.
