Will it fit?
Old Jan 2, 2003 | 08:00 PM
JSPECHB's Avatar
Default Will it fit?
Prelude H22A Type-S - DOHC VTEC 4 Cylinder 16 Valve
Will it mount in my 91' DX correct? I'll be paying $3150 shipped to my door.
<U>Specs</U>
Transmission: Hydraulic
Year: 91-01
Diplacement: 2157cc
Compression Ratio: 10.6:1
HP/Torque: 220hp@6800/161 lb-ft@5500
Redline: 7200 rpm
Old Jan 2, 2003 | 08:17 PM
ZCPOWER's Avatar
Default Re: Will it fit? (JSPECHB)
It will fit but you will have to shoehorn it in.You will also need custom axles and mounts.Then once(if)you get it in you will have to worry about weight distribution which will rule out taking curves.The h22a is heavy as hell.You will have tremendous wheel hop and traction problems.I am not saying it can't be done because it can but alot of money will be spent for it to happen.It would be easier(not much)and wiser to put a gsr engine in it and be done with it.You will most likey get flamed for posting this but dont mind it the choice is yours to make.
Old Jan 2, 2003 | 08:47 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Will it fit? (ZCPOWER)
HCP makes a mount kit I think... I would Do a CRVTEC much easier and costs about the same.
Blaze
Old Jan 2, 2003 | 08:48 PM
JSPECHB's Avatar
Damn, change of thought. Thanks alot for the info man, you just saved me a whole lot of money! If I didnt go ahead with the H22, I was thinking about the B16A! I know that will slide right in. I can also get one for $1300 delivered to my door.
Now, any suggestions on this? Sorry for all the questions. I'm new to the car sport. I use to race motocross, but had a major surgury and I had to switch sports.
Old Jan 2, 2003 | 08:56 PM
l0p3z's Avatar
b16a still will need aftermarket motor mounts.
power_of_dreams
Aug 31, 2007 07:35 AM
chris_m
Mar 16, 2007 09:28 PM
H23preludeSi
Jun 6, 2004 05:51 PM
delswol
Mar 19, 2004 04:00 PM
ShowProject
May 13, 2002 07:06 PM
