Corner Weighting a 2g crx
Old Jan 2, 2003 | 07:25 PM
ncrx1's Avatar
Default Corner Weighting a 2g crx
I want to get an idea of what values I should be aiming for when I get my car's cornerweights set, I'm aiming for a good autox/daily drive setup.
If you have had your crx cornerweighed could you post your before and after weight values LF,RF,LR,RR? And the height at each corner if you happen to have them.
Also could you describe to me the difference in handling you felt.
Thanks!
Old Jan 4, 2003 | 06:44 AM
vtecrx's Avatar
Default Re: Corner Weighting a 2g crx (ncrx1)
I was wrong so I erased this post, see my post below
Andy
[Modified by vtecrx, 11:23 AM 1/4/2003]
Old Jan 4, 2003 | 07:00 AM
spettinger's Avatar
Default Re: Corner Weighting a 2g crx (vtecrx)
side to side weight is the first concern in my opinion. not all four corners being even. that would result in less traction from a standstill, as more weight would be off the front tires. i would like to find a shop around chicago that does corner weighting, i am interested to see how the car is setup stock.
Old Jan 4, 2003 | 07:15 AM
vtecrx's Avatar
Default Re: Corner Weighting a 2g crx (2ndhandCRX)
http://www.ground-control.com/gctalk4.htm
https://honda-tech.com/zerothread?id=184761
you are looking for LF+RR=RF+LR
Andy
[Modified by vtecrx, 11:21 AM 1/4/2003]
fredshondacrx
Sep 2, 2013 08:43 PM
bla1ne
Jan 30, 2005 10:40 PM
JUNDC2
Mar 29, 2004 06:26 PM
p1ccoloz
Mar 9, 2003 09:54 PM
