engine swap question
Old Jan 2, 2003 | 05:22 PM
active_motorsports's Avatar
Default engine swap question
im thinking of buying this guys eg, but it has an automatic. Im plannen on swappin a b18c into it. Is it possible to make that swap into an automatic when the b18c is manual... need to know before i make this purchase
Old Jan 2, 2003 | 05:24 PM
ejprimo's Avatar
Default Re: engine swap question (ovrtheRedLine)
well i have an LS auto tranny for sale if that would work.
Old Jan 2, 2003 | 05:29 PM
Default Re: engine swap question (ejprimo)
thnx anyways.. but the problem being is that, i dont want the auto tranny at all. I jus needed to know if it were possible to make a complete swap from a auto-engine to a manual-engine. need to know before i buy the car.
whatVTEC's Avatar
so do you want to keep it automatic or do you want manuel? either way it's possible.
Old Jan 2, 2003 | 05:30 PM
Default Re: engine swap question (whatVTEC)
cool thnx man. When doin the swap does it require exrta parts? and money?
Old Jan 2, 2003 | 05:31 PM
Nameless RB26's Avatar
yes it's possible, and it's very easy.
All you need is the shift linkage and bolts/boots and a shift boot..
edit: and you will just need to run the manual ECU.
[Modified by Nameless, 6:31 PM 1/2/2003]
Old Jan 2, 2003 | 05:32 PM
Default Re: engine swap question (Nameless)
haha ok i didnt think itll be that easy, thought there would be more technical difficulties to go through with. thnx
Old Jan 2, 2003 | 05:36 PM
liam821's Avatar
25 Year Member
Well there is alot more then that.
You need the clutch peddle assembly, the clutch master cyl, all the clutch lines (from the master cyl to tranny), and a few other misc parts. Its not that much work if you have all the parts - but its still a pain in the ***.
liam
Old Jan 2, 2003 | 05:37 PM
chad's Avatar
Moderator
it's not THAT EASY....but if you are mechanically inclined then you can do it
Old Jan 2, 2003 | 05:39 PM
Default Re: engine swap question (liam821)
liam
OHHHH YAH! forgot lol. There's lots more..
Old Jan 2, 2003 | 05:40 PM
Default Re: engine swap question (Chad)
bummer, i really want to ask my friend who is the expert... but hes out of town and i just found this car for a sweet deal. and i have a lot of $$$ left over after buying the engine... so i guess really, money isnt a big deal in this situation...unless it runs up to an extra grand just to get the manual tranny then that'll be a bitch...
Old Jan 2, 2003 | 05:42 PM
94hondaLS's Avatar
Also youre going to need manual clutch and brake pedal. clutch master cylinder and corresponding lines. these parts dont come w/ the standard swap.
Phaze2 Mike's Avatar
Basically, unless the car is really worth, wait till a 5speed comes along. Converting to cable clutch is easy, but running the hardlines for the hydrolic, as well as placing it in the firewall, cant be fun. U could just by my hatch, pre-swaped, lol.
Old Jan 2, 2003 | 05:46 PM
Default Re: engine swap question (Nextekhatch)
thnx for the offer. i think im not going to get the EG.. ill just wait til a manual tranny w/ a good deal comes along. i want stock because it is very fun having a project car.
Donkeeyyy
Transmission & Drivetrain
May 8, 2010 09:27 AM
EG8AI
May 22, 2007 09:26 PM
Phake
Oct 27, 2004 11:45 AM
sleepyhamsterlx
Jun 6, 2003 09:49 AM
active_motorsports
Jan 2, 2003 09:19 PM
