89 CRX Si axle splines????
Old Jan 2, 2003 | 01:33 PM
dan89crxsi's Avatar
Default 89 CRX Si axle splines????
Hey I am replacing axles on an 89 CRX Si and when I went to go get the axles there are 2 different axles with different number of splines.....is there only one number of splines or do I have to wait until I take off the old axles to find out????
Old Jan 2, 2003 | 01:40 PM
4drEF's Avatar
Keyboard Humorist
Default Re: 89 CRX Si axle splines???? (dan89crxsi)
Your post is confusing. Did you go someplace and ask for axles and they said there were 2 different kinds? If that's what happened I suggest you go someplace else. There is only one kind of axle for the 89 Si. HF/STD are the only ones with different spline count so don't get those. You should be able to use axles from ANY other 4g other than the STD/HF.
Old Jan 2, 2003 | 01:52 PM
SIRX's Avatar
Default Re: 89 CRX Si axle splines???? (4drEF)
si axles have 26 splines the others are 23
Old Jan 2, 2003 | 01:55 PM
wronghand's Avatar
Default Re: 89 CRX Si axle splines???? (SIRX)
Actually the Si, DX, LX and EX all have 26 splines. The HF and STD have 23 splines. This is on the outer joint. The inner joints are the same.
Old Jan 2, 2003 | 02:06 PM
dan89crxsi's Avatar
Good thats what I needed to know when I told them I needed axles for an 89 crx si they asked me if it was 26 or 23 splines so my question was answered my Si has 26 spline......thanks all
onemore
Mar 11, 2008 07:24 AM
aznboi_2
Nov 3, 2007 06:12 PM
b16std
Jan 20, 2005 08:05 AM
MAD SCIENTIST
Apr 22, 2003 05:55 AM
muskrat
Oct 30, 2002 12:20 PM
