dpfi to mpfi
Old Jan 2, 2003 | 11:16 AM
MaaseyRacer's Avatar
Default dpfi to mpfi
I want swap my DPFI in my '89 civic DX to MPFI...What am I going to need...I did a search, but i did not find what I was looking for, mainly a parts list. I was told i could do this swap cheaply, is this true? I eventually have to do this to put a B series motor in this car. What will the Ca, smog people think about the MPFI swap on my D series motor? Also any advice from someone who has done this swap before, would be super helpful.
Thanks
Old Jan 2, 2003 | 11:25 AM
4drEF's Avatar
Keyboard Humorist
Default Re: dpfi to mpfi (MaaseyRacer)
Si/EX ECU
Various plugs from MPFI harness all with some wire attached to solder to:
4 Injector plugs
1 Distributor plug
1 Injector resistor box plug
Intake manifold including everthing from the throttle body to the injectors.
EX/Si distributor
And for a bonus - Si cam
I would like to know about the Ca smog people opinions too. I don't know if this setup would be legal even though it has the potential of being a "better" system that may be cleaner. From my understanding you can't use an intake manifold that didn't come equiped with the engine.
Old Jan 2, 2003 | 01:42 PM
Default Re: dpfi to mpfi (4drEF)
how about the wiring to the ECU does anyone have a diagram or knowledge of how to wire this.
Thanks,
Old Jan 2, 2003 | 01:55 PM
SIRX's Avatar
I have everything you would need except for the wiring harness. let me know if your interested
Old Jan 2, 2003 | 02:51 PM
Default Re: dpfi to mpfi (SIRX)
super interested in this... let me know...
Eric_Maas@csumb.edu
Old Jan 2, 2003 | 05:45 PM
auto-x's Avatar
New User
Si/EX ECU
4 Injector plugs
1 Distributor plug
EX/Si distributor
can anyone list the parts number and where to get them, i appreciate your help. thanks.
Old Jan 2, 2003 | 08:40 PM
91hatch_on17's's Avatar
Default Re: dpfi to mpfi (gud boi)
about how much would this conversion run from ( money wise)?
and it doesn't matter if it comes of a CRX or a Hatch right? or am i wrong
Old Jan 2, 2003 | 10:04 PM
MADEINIRAQ's Avatar
Default Re: dpfi to mpfi (91hatch_on17's)
right
Old Jan 3, 2003 | 03:33 AM
93eg-EKhybrid's Avatar
Default Re: dpfi to mpfi (madeiniraq)
I'm buying all of my stuff (except the wiring harness and dizzy) from JohnnyEF for $150 shipped from CA to FL. It really is a cheap mod if you can just find the parts from the right people.
BTW, I need an SI harness if anyone is looking to get rid of one, and a distributor too
[Modified by 89B16HB, 12:35 PM 1/3/2003]
Old Jan 3, 2003 | 05:24 AM
EG8R's Avatar
Default Re: dpfi to mpfi (89B16HB)
Anyone use a Z6 IM instead of a A6 IM??? How did it go for you???
Old Jan 3, 2003 | 07:01 AM
Mugen Dom's Avatar
Default Re: dpfi to mpfi (mr. skelly)
ok u do not need any whole wring harness for one u have to run 4 wires to the ecu and swap around 2 pins in the ecu part......as for the z6 mani i used it and it went ok u need the z6 eacv and the throtle body with the tps intact.....if u guys need help with the wiring u can do a few things look in the old sport compact car how to where they show u how to do it....find the post i made a while ago where i posted how to do it look under mpfi directions or something to that extent in archived it may not be there but someone else posted links in other posts im sure.....do an internet search or im me at last resorts and i can help with it a little i dont mind to many ims but sometimes it gets outa hand...good luck guys ull put in a few hours of work and be very happy with the result trust me
Old Jan 3, 2003 | 08:47 AM
importfan85's Avatar
Default Re: dpfi to mpfi (JdMB16Ahatch)
Here's a site that has the wiring diagrams. http://hybrid2.honda-perf.org/tech/4gdxtozc.html
Also, a while back, Sport Compact Car had an article on how to do the wiring, I don't remember what issue though.
One last thing you might want to try is talking to thumpu77, he seems to know a lot about the MPFI conversion.
[Modified by importfan85, 5:47 PM 1/3/2003]
[Modified by importfan85, 5:49 PM 1/3/2003]
Old Jan 3, 2003 | 10:09 AM
Default Re: dpfi to mpfi (importfan85)
OK, well if I don't need the wiring harness then I at least need the dizzy. Anybody got one for cheap??
Old Jan 3, 2003 | 12:43 PM
Is this a good deal:
$100 For everything from the manifold up. That'll include the manifold, injectors, fuel rail, throttle body, tps sensor etc. Everything
[Modified by 91hatch_on17's, 9:55 PM 1/3/2003]
Old Jan 3, 2003 | 04:37 PM
sounds pretty good to me!
Old Jan 3, 2003 | 05:34 PM
Mugen Dom's Avatar
the hf dizzy works also so if u cant find a si one get the hf one
100 is a great price make sure u get the dizzy too i had to pay for my ecu but the rest was free when i did my swap 75 for a ecu sucks hard to find si ecus
Old Jan 4, 2003 | 02:45 AM
What's a good price to pay for the distributor?? $100??
Old Jan 6, 2003 | 12:13 PM
HatchBox's Avatar
Skoobie no more...
still for sale?
run for cover
Mid-Atlantic (Sales)
Aug 17, 2011 08:29 PM
untitled
Apr 7, 2003 11:18 AM
TDRacing
Jul 29, 2002 07:37 PM
OldSchoolHatch
May 24, 2002 09:19 AM
projectcrx
Feb 17, 2002 08:48 PM
