Honda Odyssey - Service Intervals
Does anyone have the information handy on what is done on the 12000 Km service interval? The dealership is charging $80 / CAD for the oil change. That doesn't sound right at all.
Thanks!!
Thanks!!
I don't have it handy, but I think it is oil/ filter change, check of brakes, and a few other minor checks. Just ask the dealer what they are doing for the $80 and compare to the manual. I have never done the 7500 mile services at the dealer because I change my own oil. You could probably just change the oil yourself or take it to an oil change palce if you trust that.
This is the "normal" schedule.
It is in miles.
You have to do the conversion.
I recommend you change the tranny fluid at least once per year.
You'll know why when you remove the drain plug and see what's stuck on the magent.
Mileage / Months
3,750 or 6 Months Change Engine Oil & Filter
7,500 Schedule "A"
11,250 Change Oil & Filter
15,000 or 1 Year Schedule "B"
18,750 Change Oil & Filter
22,500 or 1 1/2 Years Schedule "A"
26,250 Change Oil & Filter
30,000 or 2 Years Schedule "C"
AND
Replace Antifreeze
33,750 Change Oil & Filter
37500 or 2 1/2 Years Schedule "A"
41,250 Change Oil & Filter
45,000 or 3 Years Schedule "B"
AND
Replace Brake Fluid
48,750 Change Oil & Filter
52,500 or 3 1/2 Years Schedule "A"
56,250 Change Oil & Filter
60,000 or 4 Years Schedule "C"
AND
Replace Antifreeze
63,750 Change Oil & Filter
67,500 or 4 1/2 Years Schedule "A"
71,250 Change Oil & Filter
75,000 Schedule "B"
A, B, or C Replace Engine Oil & Filter
A, B, or C Inspect Front & Rear Brakes
A, B, or C Rotate Tires
A, B, or C Inspect Tie Rod Ends
A, B, or C Inspect CV Boots
A, B, or C Inspect Suspension Bolts
B & C Inspect Parking Brake
B & C Lubricate All Hinges, Locks & Latches
B & C Inspect Brake Fluid Level
B & C Inspect All Brake Hoses & Lines
B & C Check Coolant Level
B & C Check Transmission Fluid Level
B & C Check Power Steering Fluid Level
B & C Check Windshield Washer Fluid Level
B & C Check All Cooling System Hoses
B & C Inspect Exhaust System
B & C Inspect All Fuel lines & Connections
B & C Check All Lights For Proper Operation
B & C Check Vehicle Underbody
C Replce Air Filter
C Inspect & Adjust Serpentine Belt
C Replace A/C Filter
C Replace Transmission Fluid
[Modified by 7PSI CRX, 6:28 AM 1/12/2003]
It is in miles.
Mileage / Months
7,500 Schedule "A"
AND
Replace Antifreeze
AND
Replace Brake Fluid
AND
Replace Antifreeze
75,000 Schedule "B"
C Replce Air Filter
By the way, there is nothing in that list above you can't do yourself.
Just document it all with the mileage and dates.
My van has yet to return to the dealer in it's 2 1/2 years of ownership.
As far as I'm concerned it never will.
Seks
Nov 27, 2014 02:19 PM
o8EXLCoupe
Jun 3, 2008 06:30 AM
AutoXer
13
Sep 8, 2005 12:11 PM
