t04s/60-1?????
i am in the market for a new turbo. i was wondering if anyone here has a t04s/60-1 w/ an .82 a/r? i think that is what i want to go with and i just wanted to here some opinions. it is either that or a t62-1 w/ big shaft. this is for a stricktly street car with a 2.0l stroker motor.
a few of the qusetions:
around what rpm does it begin to spool?
where does it reach max boost?
how horrible is the lag?
ect.
thaNX
ect.
thaNX
that turbo is gonna have horrible lag time for a street car, i would only put that turbo on a track car. I have a 2.0l motor too and am going with a T3 60-1, great turbo for street use.
Well if it's strictly for street use then maybe you want to got with t3/60-1 so you can spool up faster.
What's your compression at? If you have low compression then you might have a tough time spooling up a t4/60-1 , esp with a .82 a/r. But then again you have a 2.0 L so hmmm... You might be able to spool that sucker up @6k-7k or so.
Your best bet would be to with a a t3/60-1 or go with lower a/r on the exhaust side.
edit- spelling
[Modified by ekb18c, 8:49 AM 1/2/2003]
edit- spelling
the motors compression ratio is 9.0-1. but i am looking to run 1 bar daily and more than 22 psi at the track. the motor is built to hold up to 40psi as long as there is the propper fuel. the turbo i have now is a t3/4b .57 and that spools up aroun 43-4500 and holds throughout the rpm range. i liked it but, the other day i drove a car with a t3/4 60-1 and the same motor and it just seemed to be way more powerful at the same boost. thats why i want to go just a little bigger. i am deffinitly open to other suggestions though. is it possible for you guys to post some oics of tour turbos? i just want to judge size
thaNX
thaNX
PWRVTEC
Oct 9, 2002 12:05 PM
