Squeaky Suspension!! Cambers??
I just installed Tokico full coilovers with Ingalls cambers all around dropping my 94 EX about 2 inches. I constantly hear squeaking and creaking (especially in the front) when I drive anywhere especially just slowly around my parking lot. I do need to install new bushings all around since mine are dryrotted but is there anything I can do to stop the squeaking? I have heard that cambers can squeak and cause this, how and with what should I lube them with?? And how long will it last before the squeaking returns?? Thanks!
J
J
You will find the answer here...
https://honda-tech.com/zerosearch
Not to worry, the noise that you are hearing is coming from your front camber kit. The polyurethane bushing make alot of squeaky noise when your A-arm's move. What I did with mine is I sprayed some liquid lubricant all over them and the noise completely stopped. So far it's been about 2 months and still not a single noise.Works for me so it should for you to. Good luck!
Awesome! That is good news! What brand of lubricant did you use and should I just spray it right on the camber itself? Any other parts I should focus on? Thanks for the tip!
eL
Aug 14, 2004 11:03 PM
