92 si motor in to an 90 dx
i just want to double check that the mounts are the same,
what all do i need to worry about, can i use my dx tranny on to the si motor,
the only thing i thought i would need to worry about is the wiring and the ecu.
help please
[Modified by slowpokesi, 3:35 PM 1/2/2003]
help please
you can use the tranny i would recomend the si tranny better gear ratio for the z6
and yeah the mounts are the same.
if your not doing the obd1 convo use the non obd teg ecu 88-91
pm me if you have questions
edit: apexi Vafc
[Modified by 4gsicivichatch, 10:33 AM 1/2/2003]
edit: apexi Vafc
are the mounts the same? YES
can i use my dx tranny on to the si motor? YES
the only thing i thought i would need to worry about is the wiring and the ecu? YES
That is the basics. You will either need a OBD-1 to OBD-0 conversion and run the VTEC ECU, or you will need to wire in a VTEC controller to handle the VTEC activiation on your stock ECU (You will need to change to an '88-'91 Si ECU, or a '89-'92 Integra ECU, you cannot use the DX ECU).
yes you need the injector box 92+ (to use the injectors in the z6) and you need schematics for the mpfi off of the ecu run the 2 wires you need from the ecu to the box and use the 2 existing dpfi wires also.
im going with the vafc you get a ton more tuneing controll with that you will kick yourself later on if you go with somthing else
i would go hondata if i had the money
mounts are not the same as the ones on your car... but yes u gotta use the ones on ur car and they will work fine...
u can use ur stock tranny but its recomended for you to get a 89-91 Si tranny... u need to convert from DPFI to MPFI so u need dizzy, injectors, and inj resistor, i got some of the info in my signature link,... might clear up some of ur doubts.... DPFI to MPFI isnt all that complicated... and theres a few options...
Use the resistor box and 4g si/90-91 teg injectors
88rexdxa6ed
11
Apr 18, 2003 06:29 AM
ysrhatch
Feb 8, 2002 07:03 PM
