Please help me out!!! Just look at least! topic- pulling tranny
Old Jan 1, 2003 | 11:05 PM
TRE_'s Avatar
Default Please help me out!!! Just look at least! topic- pulling tranny
Well, it looks like my clutch throw-out bearing fork is bent. It's probally due to the ACT SS clutch and xtreme pressure plate. Its a stock fork so I'm sure it bent due to the stiffness of the ACT. Anyway, it looks like I'll be replacing that fork and the throwout bearing here in the next couple days. My question to you guys is -- how easy/hard is it to pull the tranny? Body -- 91 CRX engine- ZC tranny- ZC. Also, what engine do I order the throw out bearing and fork for? I really need your help so if you have any input or even e BUMP please post for me. I need to get my car back and running.
Thanks a million guys!
Old Jan 1, 2003 | 11:29 PM
USDM 4G VTEC's Avatar
Default Re: Please help me out!!! Just look at least! topic- pulling tranny (glowing_rotors)
IMO its always better (at least hondas) to pull the engine w/tranny out togheter instead of jus tpulling the tranny out..
it took me 4 hrs just to swap my 4 speed trany to the Si one with 3 taco bell runs and BS around a lot...
try to get a nice set of tools.. see if u can borrow some air tools and a cherry picker...(will make life a lot easier)
i guess u can use a D series fork.... they will work on it
Old Jan 1, 2003 | 11:36 PM
TRE_'s Avatar
Default Re: Please help me out!!! Just look at least! topic- pulling tranny (JDM EF9)
Thanks for your reply. My friends shop has air tools and just about every other tool there is. We've pulled a few engines there but I honestly dont want to pull the whole thing. On my friends EG w/ b18 we pulled the tranny in a couple hours and it was pretty simple. I was just hoping it wouild be the same w/ my rex.
Thank you again sir.
Old Jan 2, 2003 | 07:10 AM
keithv's Avatar
well you don't have to pull the motor, but i agree with JDM EF9 that is is probably easier. mating the tranny back to the motor is always a bitch, nevermind if you have limited room since the motor is in the car. but do as you wish.
as for the fork, a civic si one will work fine.
Old Jan 2, 2003 | 11:11 AM
TRE_'s Avatar
Default Re: Please help me out!!! Just look at least! topic- pulling tranny (breaka_1_9)
Thanks for your reply. My friend is conviced that it will be easier to pull just the tranny, and hes good at this type of stuff so I'm just going to do w/ he thinks is best. Like I said we've done this before and it was fairly straight forward. I'll be ordering a Civic Si fork soon, what throw out bearing do I order? One for a civic si?
Thanks again man.
Old Jan 2, 2003 | 11:36 AM
keithv's Avatar
Thanks again man.
the civic throwout bearing will work as well. basically the ZC tranny is a civic tranny. the differential is where things get weird.
Old Jan 2, 2003 | 11:53 AM
Kamin's Avatar
pull the transmission!!!
ive had to pull mine 4 times in the past 3 months (dont ask.) and ive gotten the removal time down to 75 minuets with hand tools.
its not that hard, the hardest part is popping out/in the axle's
Old Jan 2, 2003 | 12:36 PM
Loaded Butane's Avatar
Default Re: Please help me out!!! Just look at least! topic- pulling tranny (Kamin)
I would just pull the tranny. Its not hard at all, but then again that might be because I have had to do it a few times.
Old Jan 2, 2003 | 01:14 PM
TRE_'s Avatar
Default Re: Please help me out!!! Just look at least! topic- pulling tranny (Loaded Butane)
Thanks for all the help guys!
foress_89
Oct 13, 2007 06:28 PM
Punker1234
21
May 29, 2005 01:22 PM
sohc hatch
12
Sep 2, 2004 07:04 PM
Sherm
Feb 22, 2004 04:07 PM
turbohf
11
Feb 25, 2003 06:23 AM
