88 crx window problems!!??
Old Jan 1, 2003 | 10:49 PM
RapeV-8's Avatar
Default 88 crx window problems!!??
will 89+ crx driver side window fit in my 88 crx????! i have a lot of 89+ crx doors at home and just wondering if it is the same since 89+ crx have seatbelt on the door so the window is smaller!!
Old Jan 1, 2003 | 10:51 PM
I Gotta Question's Avatar
Default Re: 88 crx window problems!!?? (igotcrx)
89 doesn't have the seatbelt on the door.
Old Jan 1, 2003 | 11:17 PM
50shotRex's Avatar
88-89 is the same i thought, but the window wont fit, i tried to put a 89 window on a 91
Old Jan 2, 2003 | 08:31 AM
RapeV-8's Avatar
FYI 88 si,dx,hf have the seat belt on the frame...89 crx si,dx have the seat belt on the door but 89 hf have the seat belt on the frame. 90-91 all crx have seat belt on the door.
Old Jan 2, 2003 | 08:43 AM
Wiz's Avatar
Wiz
Actually, depending on the month it was manufactured, the 89's can come with door mounted belts or pillar mounted belts.
In theory the window from the 89 should fit the 88. It will not fit a 91 crx. the doors are, I think, slightly longer and thicker
give it a whirl, give me an update on your findings.
Old Jan 10, 2003 | 07:02 PM
RapeV-8's Avatar
ok i measure the window and the 89+crxs have a smaller window(2 inches short) thean the 88 crx btw i have a pair of 90-91 crx doors on my 89 crx si and it fit perfect also only 89 hf is the only crx that dont have the seatbelt on the doors
rexcody
Jul 14, 2008 04:35 PM
jakscivic
Oct 3, 2007 09:31 PM
dtown_racer
Feb 21, 2005 04:35 AM
m_mathers_69
May 27, 2004 12:32 AM
didyouhearthat
Nov 13, 2003 08:39 AM
